Want to totally clean hard drive to sell computer
    Scholar:
  • 141 Answers
Hi Kiwilass,
When you say totally clean, are you referring to the internal cleaning or the external cleaning?
if its external...hmmmm not advisable
if its internal, then:
for IDE harddisk: Change the jumper settings to slave and slave it on another pc, power ON pc and look for that new drive, right click on it then select FORMAT.( dont do a quick format )
for sate: i think same goes with sata, just that, you dont need to change the jumper settings for it does not have one
Posted on Jun 24, 2008
    Guru:
  • 859 Answers
All hard drive manufacturers have utilities you can download from their web sites that will write all zeros to your hard drive from a bootup environment.
Then if you get a hold of a copy of Hiren's Boot CD, you boot to this from your CD/DVD drive and select Hard Drive utilites and there is a program called wipe disk.
A free program called GDISK, will wipe a drive according to DOD standards. It doesn't com with a boot loader you can use to boot from your CD/DVD drive, you need to use Nero Express to create a bootup disc using the built in boot image from Nero, add GDISK to it and then once you've booted up, you type the command
gdisk /?
And you will subsequently see command line codes to do a disk wipe. Through trial and error you'll get this right unless you are already comfortable with command line structure.
Hiren's is the best tool and invaluable to have around.
You can find the home page for it here.
Regards,
Worldvet
2 Suggested Answers
  • 10406 Answers
SOURCE: Want to sell computer, need
Search online for "free disk wipe" software. It will write "zero" data-bytes all over the disk-drive.
Or, remove the disk-drive, and take a sledge-hammer to it. The new owner probably would want to install a newer, bigger, warrantied, disk-drive, before they install an Operating System.
Posted on May 22, 2011
How to erase the hard drive?
You can use a HP recovery disc for your model computer which will return the computer to out of the box condition. You may need to purchase this disc from the HP WEB site.
If you just want to wipe the hard disk clean and sell it without an operating system installed then you can use this program.
Wipe Data off Hard Disk with Darik's Boot and Nuke, (DBAN) Create a Darik's Boot and Nuke on CD disc, then boot up the computer with this disc. http://www.dban.org/download
Feb 28, 2013 | HP Pavilion A6530f Desktop Pc
My HDDR500E03A 500 GB is only showing 3.98 GB on total memory, what happened to the rest?
The 3.98 GB you are seeing is probably your total RAM memory and not the storage capacity of the hard drive. RAM memory is completely unrelated to the hard drive capacities.
Double click on the MY COMPUTER icon.
You should then see all the disks and drives that are currently connected to your computer. Your USB hard drive should be one of the drives listed there.
Right click on each of them and select PROPERTIES from the menu shown. This will show you the storage capacity of each drive including how much space is used and how much is free (empty).
Good luck.
Mar 15, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
I want to clean my hp dv 4000 hard drive in order to sell......How do I do that.......i still have the software/hardware to restore.
Have a look on ebay under computers then hard drive erase. There you can get discs for £1.79. I have used a version of these myself and they work very well. Don't know whether you are planning to reinstall OS or not. Hope this helps.
Jan 22, 2011 | HP PAVILION DV4000 SERIES 80GB (4200 RPM)...
I want to erase everything on my external hard drive. How do I do this?
If you aren't sure what you're doing, bring it to a service tech or you may render that external hard drive completely useless:
Before you start cleaning make sure you back everything up onto another disk. If you are giving your computer away check with the person or organization to see if they plan on cleaning your hard drive for you. However, the best thing to do is to clean it yourself.
Download a hard drive cleaning program or go to a computer store that sells computer software and buy the program. This is the safest way to make sure the hard drive is all wiped clean. Running the software program over writes all the data on your drive, making the hard drive impossible for anyone to read. The software works by over writing the drive many times.
Make sure you give yourself plenty of time in wiping your hard drive clean because if you have a lot of stuff it will take longer to clean.
Once your running your program and the box comes up to erase your hard drive don't forget that this process is irreversible. You will now type in the word format drive letter and hit confirm that you want to erase everything on your computer.
Installing a new external hard drive if you are not getting rid of your computer, is another option you have. You still go about erasing the old drive because you're getting rid of your hard drive. Install the new one.
Jan 01, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
How i can erese all my hd to install a new so
If you want to erase the hard drive, the best way is to format it.
Jun 25, 2010 | Western Digital Caviar SE WD1600AAJS 160...
RETRIVE HARD DRIVE INFO
If it is making loud clicking noises you were told correct. Chances of getting anything off it are remote unless you are prepared to spen a lot of money on proffesional recovery services.
Apr 11, 2009 | Magix Music Cleaning Lab for PC
How to clean up hard drive on ibm thinkpad 2645 600e model
i) when you open My Computer you will see partitions or your hard disk partitions(such as C, D, E , F)
   right click on D and you will come with some option, click on format option and all the data on your drive will lost or cleaned up completely,,
continue this process withother other drivers, other than C Drive since it has system files and u cant delete it ......
ii) if you even want this delete try to follow the procedure of loading or formating xp or freshly load xp on computer and follow onscreen instruction you will see the C Drive and now press the D to Delete that drive and follow some instructions...and totally drive is completely cleared
Thanking you
M. Sridhar
Dec 09, 2008 | IBM ThinkPad 600E 2645 Notebook
Hard Drive Crash
then it would be total bad can u try to install it on other comp as a slave drive to get in it to pull info out if they total die there sno way unless you fbi to get info off k
Oct 07, 2008 | Western Digital Protege WD400EB 40 GB Hard...
How can i format my hp desktop??
Well there are a couple different solutions. If you have another hard drive replace it with your other one and make the one that you want to format the secondary hard drive. Then after you boot the computer, all you gotta do is go to my computer and which ever drive the hard drive is set up on you can right click on the right drive. Go to where it says format and click on it and then follow the instructions.
You can also format the hard drive if you got a windows disk. Just put the disk in your cd-rom and restart the computer and then go through the setup process. You will get to a point where it will ask you if you wanna keep the files the same or do you wanna format the hard drive. There are two options for fomatting: There is a quick format or a full format. If you wanna totally wipe everything off the hard drive make sure you do the full format. It only takes a little while longer than the quick format process, so you are just better wiping it totally clean and then reboot windows on the hard drive when it is done formatting......
Jul 27, 2008 | Computers & Internet
Selling Old Computer - Deleting all Personal Info
Melanie, here is the free version of Active@ Kill Disk Hard Drive Eraser. It will erase your hard drive so no one can get any sensitive info off of it.
http://www.pcworld.com/downloads/file/fid,22920-order,1-page,1-c,alldownloads/description.html
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
