Question about Panasonic DMRES15 DVD Recorder
ERROR MESSAGE..... When i put the power on, it displays "LD FVU" for a about 10 seconds, and then it opens the tray and displays "INSERT DISK" and it just stays there. Any DVD I put in it, it sends it back out.
  • Anonymous Jun 30, 2008
    I think that means that it is asking for a service cd to be inserted. I have a Panasonic DHR-EM55 and tried to increase the size of the hard drive - when I put the new hard drive in I got that message. Searching the forums indicates that the unit is asking for a Service firmware CD to be inserted so that it can initialize the Hard Drive.
    Not sure if this is applicable to yours or not. When I put the original Hard Drive back in it works as normal.
  • javor Jul 29, 2008
    SAME PROBLEM. DOWNLOADED FIRMWARE. NO POSITIVE RESULT. CD REJECTED
Had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Posted on Aug 16, 2008
  • 426 Answers
Sounds like a bad or dirty laser try using a cleaning disk, otherwise you might have a disc stuck in the reader and the system doesnt know what to do with it
Posted on Jun 24, 2008
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
Xbox 360 console can't read disk
If your console has stopped reading discs this can be because the receptors on the back of the drive have overheated and to fix it you will need to send it in or use a good repair guide to do the job.
Nov 25, 2009 | Microsoft Xbox 360 Console
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi when I turn on my Panasonic DMR-EZ45VEBS I get an error that states 'LD FVU' then the CD slot ejects. It them simply doesnt allow me to do anything. Has anyone experienced this? If so can you help fix...
I get exactly the same problem with my Panasonic EZ48 recorder.
It also displays FM List DL error .It sometimes sorts itself out by holding the on switch for 20 seconds.
Ian
Nov 29, 2008 | Televison & Video
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Disk Tray
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Sergio
Mar 29, 2008 | Sony RDR-HX825 DVD Recorder/HDD Recorder
DVD does not start set up automatically
Hi Turtis,
Did you ever solve this?? I have a similar problem on my DMREZ25EB and got told it could be resolved by updating the firmware which is what the FVU is meant to mean. However, I can't find my version of the Firmware on the panasonic.com site. If you solved this could you let me know what you did.
Thanks,
Vee.
Aug 23, 2007 | Panasonic DMRES15 DVD Recorder
Panasonic DMRES15 DVD Recorder Logo
2,463 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
