Eror code on sharp copier AR-M276
Could anyone help me with this error message, the copier has been down for awhile, There was a code on the screen displayed " H4-00". I've already cleared that message, but there's a new error comes up "E1 -15"
Could you please help me, cos my clients really need this machine to be up and running...
Is there any ways I can cleared this error message,
thanks.
Inoke Valu
Manager
PRO-TEC SERVICES
Vava'u
Kingdom of Tonga
  • nokevalu Jun 24, 2008
    hi is there any ways i can reset the memory page or cleared this error message without replacing the IMC BOARD.
Reset #*C* 14 start 0 start 1yes
Only other suggestion in book is replace memory modules plugged into imc board.
Posted on Jul 06, 2008
  • 22 Answers
UNRELATED PROBLEMS.
H4 = MAIN HEATER LAMP ABNORMAL LOW TEMP. THE FINAL UNIT BEFORE PAPER EXITS. HAS TO BE HOT. LAMP OR THERMO-FUSE? CHECK CONTINUITY LAMP WIRE IN THROUGH WHOLE PATH TO OTHER LAMP WIRE OUT.
E1-15 = IMC board Page Memory error/SRAM
error. MEMORY FULL? Mfr. says "Print Buffer Page Memory or Work SRAM abnormality"
SORRY NO MORE.
Posted on Jun 24, 2008
How can i fix error L4-01 for Sharp AR-M276?
hi you should chek drive system and fusing. dv cartridge. drum unit rotations ...... if there's was normal change main motor.
Sep 29, 2014 | Sharp Office Equipment & Supplies
Ar-m276 u2-40 error
its bad comunication between the toner cartridge and developer so you need to replace the toner cartridge or the chip on the rear side of it
Mar 14, 2012 | Sharp AR-168S Copier
How to clear u2-40 error for sharp ar m276
This is error for Error in MCU-CRUM chip communication. Probably because of developer unit has bad contact.
Try to reconnect developing unit and then turn on the copier. If problem persist call service!
Hope that helps!
Sep 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
I got H4-00 problem in my AR -M276 Photocopy
Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Jul 27, 2010 | Sharp AR-168S Copier
SHARP AR 5020 error F5-02
you reset your eror code program c#0#
May 30, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-m276 printing error message
There is a known problem with adobe 7 printing on this model. Unistall the PCL6 driver and re-install it using the PCL5e driver instead. This will fix your problem.
Oct 04, 2007 | Office Equipment & Supplies
660 people viewed this question
jasbo
jasbo
