Question about Samsung ML2251N Laser Printer
Cannot print the printer shows red light on online/error.when shorty on the printer ,it gives a loud drrrrr...... sound .
    Problem Solver:
  • 13 Answers
Toner cartridge remove than close cover if again that noise its means that heater unit is jammed due to over heating. If printer initialize normally its mean that your toner is jammed.
Posted on Dec 03, 2013
SOURCE: online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
SOURCE: In my printer power is on and red light will appears
I have to install this printer in xp professional o.s.
than what can i do now
Posted on Mar 22, 2009
tolexade
  • 81 Answers
SOURCE: Canon Pixma MP190 all-in-one will copy offline and
this sounds like a virus any ways, make sure u have a very good antivirus, remove and reinstall the printer with the driver but first go to the printer delete all the printers installed manually i.e after uninstalling the printer and its still showing the printer at printer and faxes, then reinstall it.
Posted on Jul 22, 2009
  • 68 Answers
SOURCE: I try to print and the printer just prints the
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Posted on Oct 08, 2009
pineworks
  • 4041 Answers
SOURCE: error code
Hi You can Try gave it go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Lp2844 sound is coming from printer while printing
Green light red
I've a Zebra LP2824 printer , It gives me the Green-Red error .. And the manual guide told me that's a problem with flash programming .. What can I do to solve it ??
Feb 12, 2016 | Zebra LP 2844 Thermal Printer
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
The bp20n ran out of toner. We put in a new
I have to respond to this posting with a solution because I cannot track responses if I mark this as a "Clarification".
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | Ricoh Aficio BP20N Laser Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Red Indicator Light stays on-- "Online Error."
tray to powering off the printer wait about 10 second then swith on
i use to be too
Apr 29, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Quit Printing & Loud annoying sound
The sound is coming from the new toner cartridges. The roller is sticking and causing the gears to make that noise. I removed the toner cartridge and manually turned the roller until it turned smoothly. (this a little hard but it worked). no more noise!
Dec 09, 2007 | Konica Minolta magicolor 2300DL Laser...
Samsung ML2251N Laser Printer Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
