Question about Whirlpool Dryers
My whirlpool dryer when first turned on heats up but doesnt stay hot. i was going to replace the solenoid coil but don't know if i have to take off the front panel or rear panel to get at them.
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 24, 2008
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
Here is the coil kit to order.
Nov 06, 2012 | Whirlpool Dryers
Kenmore model 11072842100 Gas Dryer, just stopped heating up, heats a little then stops heating ? thermal fuse? ?? thanks
The thermal fuse dies and stays dead. No more power would be applied to the gas assembly if it melts. The dryer would still run thoughthemobilian_188.jpgthemobilian_189.jpgThe ignitor is either going to be good or bad no in between. The flames sensor can stick with age but this is rare, The bi-metal sometimes takes a while to reset on these but like I said it is a rarity. themobilian_190.jpgThese coils however are notorious for getting hot and quitting.
Solenoid replacement 101 themobilian_191.jpg More info and manual is HERE
Nov 18, 2010 | Dryers
Lgr5620kq1 dryer,heat comes on but does not stay on,
If you find that the dryer initially lights, then goes out and the igniter coil glows, then also goes out, it's the valve solenoid coil, about $25.
There is a temperature limit switch as well. This usually either fails entirely (no heat at all) or operates the burner out of the normal range (often showing up as clothes taking too long to dry).
A clogged dryer vent will cause problems with heat cycling, too.
Apr 07, 2010 | Whirlpool LGR5636L Gas Dryer
Heats then stops
You need to replace the 2 solenoid coils on the burner valve . When one of them gets hot from electricity going thru it , it opens ( shorts internally ) . After the dryer cools down , they will work again until they warm up , then , no heat . Take your complete model number , when you get the parts .
Sep 22, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Dryer wont stay hot. it gets cold after first load
If dryer lights for a few minutes and will not stay lit, I believe the solenoid coils will need to be replaced. Click on link below, enter your model number lgr5620kq1 in model search feature and go to the dryer page it shows a breakdown view of your dryer. Also go to common solutions and look for gas dryer problems. I will also be here to help you, Sea Breeze
Mar 21, 2009 | Whirlpool Dryers
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Overheated , now fixed but have no powe
You may hae a non-resettable thermal fuse that opened.. when that happens.. system won't operate..
Sep 03, 2008 | Whirlpool LEB6300 Electric Dryer
Dryers Logo
156 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
