Question about Denon AVR-3805 Receiver
Denon AVR 3805 video problem
Hi
I have been using this receiver for the past 2.5 years connected to DVD, STB, Foxtel and satellite to watch movies etc and to a projector using component. Last week, I could not get the video from all these components, although I got the audio from all the units. I tried various connections in the receiver (component, S Video, composite), but no picture output.
Also, is it necessary to upgrade firmware and if so, could you please let me know how I could get this firware and upgrade
thanks
tivi
the020@csiro.au
  • Tivi123 Jun 29, 2008
    Dear tech48
    Thank you very much for your time in replying to the post. I appreciate your time and input very much.
    Yes. resetting the system has worked. I have cleared the video glitch I had with the 3805 by resetting it. I spent a lot of time in trying to solve this issue before, but your suggestion has helped me to solve it within minutes. You are a real 'GURU'
    RE, upgrading firmware to 3805, service agent here in Australia informs me that Australian models of 3805 does not need firware upgrade. Is that true?. What benefit I have in upgrading firware?
    Thank you once again for your help
    tivi
    the020@csiro.au
  • ckim828 Nov 19, 2008
    from ckim828
    Hi!
    I had have same problem, about a year ago lightning hit my house. Everithings working fine except video on my Denon Receiver AVR 3805.
    I read above article today and tried reset as mentioned.
    It worked! Fortuneatly, I didn't throw away this beautiful receiver.
    Thank you!
    President:
  • 624 Answers
Some of these Denons do require a firmware upgrade, but it is a very complicated process and you use your computer to do it thru the RS-232 port if this model has one. I can check on Monday to see if there are any for this model. I work at a authorized Denon repair center and fix lots of Denon receivers including this model. I just can't remember the specific details of every model of receiver I work on.
The only end user procedure you can try is the reset. If you try this reset procedure please be aware that all the settings you have made will be cleared and the unit will go back to the factory settings. You will need to input all of your custom settings.
This is no guarantee that it will solve your problem, but it may be worth trying. Sometimes the microprocessor software gets corrupted for unknown reasons, and a reset will clear out that type of problem.
With the power off you need to press and hold the "Pure Direct" and the "Direct" buttons on the front of the receiver and keep holding them in at the same time, then you would turn the power on while still holding those two buttons in. Once the unit turns on and you see and hear it turn on you can let go of the two buttons you have been holding in. Your receiver should now be reset, go ahead and make sure you assign the proper video inputs to the source you are using for the TV. Your owners manual should explain this. If you need help with it let me know and Monday I can look it up.
If this does not help you probably have a problem on the video input board, it has several IC's for switching and a buffer IC as well. It is controlled by the main system microprocessor also. The actual problem could be any one of those or even a bad voltage regualtor or transistor. It is not anything that the end user can repair unless they have experience in electronic trouble shooting. it also requires the proper equipment to troubleshoot with.
If you have found this information to be valid and useful, a "FixYa" ratings would be appreciated. That is the only reward I get for the help I offer here.
Thanks,
Dave
Posted on Jun 28, 2008
  • Dave DeGain
    Dave DeGain Jun 30, 2008
    This model does have a firmware upgrade, but I can not say about the ones down under. I suspect they are the same as those here, but don't know for sure.
    I would not do a firmware upgrade on anything if I am not having some sort of regular problem that is just a glitch in the software. After all, that is all that a firware upgrade is, a newer version of software that is for a hardware type of devise.
    I have seen in some circumstances that after the firware upgrade, you have more problems than you started with. If the firmware upgrade is somehow interupted or in any way stopped before it is complete, you may have a dead unit.
    So, unless you think it really needs it, I would't worry about it.
    I am thankful for your kind words, they are appreciated. But yo may not see much of me here anymore, I can't put up with so many so-called "experts" giving so many people just terrible information. I hate to be associated with that type of thing. There are some good experts here, just too many that are not.
    Thanks again,
    Dave
seems like i have the same problem. where can i get the firmware? is it only available via denon repair centers?
thanks
Lars
Posted on Jan 20, 2010
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Jan 05, 2010 | Denon AVR-3805 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
I have a Denon AVR 3805 and can't get the video to work on the TV.
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-3805&imageField.x=10&imageField.y=9
cut n paste the whole link.
Also check all you cables..If you have spares try them in place of the others
Jan 18, 2009 | Denon AVR-3805 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
How to connect Wii to Denon AVR 3805
cut and paste the link.
All the info you need should be there
Jan 10, 2009 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
HTPC connected and no Video out
did you check your I.mode or analog buttons on your remote?
Dec 14, 2007 | Denon AVR-3805 Receiver
Denon AVR-3805 Receiver Logo
1,644 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
