Question about Samsung HLP4663W 46" Rear Projection HDTV
Power outtage has my dlp hdtv actin weird
I had a blackout 2 days ago due 2 bad weather...i do have the Monster Surge Protector working w/ my tv...im not sure exactly what happened but there is now a blue box in the dead center of the screen that wont go away...the remote is not workin and even the buttons on the tv arent working...the audio works fine and so does the picture though.
    Champion:
  • 217 Answers
Unhook everything from the tv and wait for a few minutes, go into the factory mode and do a reset, factory mode code is , mute-182-power
Posted on Jul 18, 2008
I came home to find that the tv won't turn on. I unplugged and plugged it back in. Just won't turn on and it was on a surge protector. Unplugged it from there and directly into the wall still nothing....
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
Hope this help in solving the problem, Take care...
Sep 13, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony wega kdf-e50a10 hit by lightning now it will not turn
follow the power cord and just check the input fuse if you've got a surge protector on it it may have just blown the fuse from a spike. It doesn't hurt to try. This fuse is inside the tv.
Sep 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My HP HDTV trips my circuit brakers
1) Try with a different surge protector. The oine you're using could have a short-circuit
2) Try without a surge suppressor, at least for a day
3) Does the circuit breaker trip when something else starts running? Your microwave, fridge, dishwasher, etc.?
4) Check the user's manual of your TV, under SPECIFICATIONS. Check for "POWER REQUIREMENTS". If the power requirements listed is greater than 15 Amps or 1,700 Watts (assuming you live in the USA and your household is 110-120V), then the circuit breaker will almost always be triggered by the TV. Most circuit breakers inside a house are 15 Amps.
The only option you have is to replace the circuit breaker for one that has more Amps, but doing so on your own without having and electrican check if the wiring will hold the extra load is extremely unadvaisable. You may end up with an electric fire in your hands.
May 29, 2009 | HP PL4260N 42 in. Plasma HDTV
Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Surge protectors
Hey Laduell,
Before anything else, it's probably best to explain the differences between power surges and flux. Power surges (also called voltage or electrical spikes) are generally caused by a sudden, massive increase or decrease in the voltage flowing through an electrical circuit. Flux, on the other hand, can be defined as the actual voltage flowing through a circuit at any given time.
Whenever an electrical device turns on, turns off, or changes modes of operation, it can cause slight disturbances or differences in the voltage flowing through an electrical circuit. Exactly how much of a difference is made may be dependent on the type of electronic device attached, though major electronics and appliances will have a larger "pull" than smaller devices, like clock radios. The more devices are attached to the same circuit, the larger these voltage differences may become.
This fluctuation in voltage - combined with other electrical, magnetic or radio frequency interference ("noise") - has been known to cause problems or even damage in some electrical devices. To prevent such damage, many manufacturers may include "noise reduction" or "EMI/RFI protection" features in their surge protectors.
As both Dynex and Monster Cables appear to include such a feature in many of their products, the price difference you are seeing may simply be related to the number of additional features that the Monster Cable surge protector offers, though this cannot be guaranteed.
If you're in doubt about your purchase, I would strongly suggest contacting either manufacturer for more information. Most manufacturers are able to provide you with detailed descriptions of their product features, and one of the two may be able to point you towards an online FAQ if one is available. Dynex's toll-free hotline is 888-305-2204, and Monster Cable can be reached at 415-840-2000.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 18, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
148 people viewed this question
Henry  Thomas
Henry Thomas
