Question about GE Spacemaker JVM1640SJ Microwave Oven
Hanging a microwave with no rear wall (peninsula cabinets)
I have the same problem as described in this post:
http://www.fixya.com/support/t354697-microwave_installation_under_cabinet_no
thanks in advance for your input!
  • 1 more comment
  • haverstock Jul 01, 2008
    Thanks for the reply.
    The crux is that there are no studs to which one can mount the rear support bracket, as instructed by the manual (I have an LG but the problem is common to all rear mounted microwaves). It's a peninsula cabinet system secured into the ceiling joists/soffit (I don't know what this is called exactly. There are extra beams of support in addition to the joists, intended for securing the cabinets into the ceiling).
    I don't want to have to build a hanging (4-5" wide) rear wall. I think the microwave can be supported by the cabinets as they are presently anchored into the ceiling. In which case, I see two options:
    1) some less obtrusive rear supporting structure/piece, such as 3/4" wood or plywood, which would be secured to the rear of the cabinets and to which I can attach the rear mount (but using different/shorter fasteners), or
    2) a side rail or shelf system that supports the microwave from the bottom (instead of the rear). The shelving or rails would have to be secured to the cabinets at either side of the microwave. The problem here is that there is only a 1/4" extra width at the sides, enough for brackets or rails or shelves, but not for the bolts needed to secure them to the cabinets, as they would protrude beyond the supports themselves and prevent the microwave from fitting between the cabinets.
    Thanks in advance for any ideas!
    -Ryan
  • rbworford Sep 16, 2008
    How to mount a microwave above an island stove? Need external vent capabilities. No back panel or wall to hang the microwave on currently exists (or could be easily added). Need to hang or get some side brackets. Any ideas??
  • sf123123 Jan 07, 2009
    Can you use the hanging microwave shelf to hang a regular counter top microwave over a slide in range? The stove currently has an exhaust hood, I will be removing this. Do I need a special electric outlet for this or can I plug it into the current outlet that I am currently using?
    Thanks
  • GE Master
  • 9,086 Answers
At a glance, the installation instructions seem to assume you will be mounting it to wall studs.
If you don't have the installation instructions, you can download them here.
If they do not address this issue, I would suspect you may need to have a mount built.
If this is the case, I would contact the folks at places like Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
How do i take microwave off wall i took 2 bolts off in cupboard above microwave and microwave did not budge at akk.
There should be two or three bolts inside of the cabinet above the microwave. Remove all bolts and then pull top edge of microwave forward (away from wall). It pivots on a mounting plate which is secured on the wall. Pivot forward and lift microwave up a little bit off of the ledge of the rear mounting plate.
Make sure to feed the electric wire (plug) through the hole in the cabinet as you pivot and remove the microwave. Sometimes cooking grease will make the microwave stick to the cabinet. So after removing the bolts use gentle force when pulling on the microwave.fce1346.jpg
I hope this helps and good Luck!
Feb 16, 2010 | Magic Chef CMV1000B Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
Nov 05, 2008 | Microwave Ovens
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Peninsula otr microwave installation
I cannot comment on this. On something that is non-standard and specifically warned against in the manual, I would only comment if I were there to inspect it.
I would get a pro's on-site opionion.
Jul 30, 2008 | Microwave Ovens
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,833 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
