Acer Aspire 3000 Notebook Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer aspire 9301 notebook - cannot find acer recovery management for this model running windows vista ultimate
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Nov 27, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1540072
Points
28391
When booting, at the point when the POST screen dissapears press F8. It may take some practice to get it to work as there is a very small time window.
Select restore or recovery from the menu. It is a hidden partition on your hard drive. If it is corrupt or missing, use your windows disk at that point and select recover.
Hope that helps.
I want to download acer empowering technology for acer aspire 5738-6922 with Vista Ultimate 64bit (from Brasil - thanks!)
Empowering bottom doesn't work on Acer Aspire 4730z with 32-bit with windows vista ultimate. I have no Empowering driver for vista.
1helpful
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Recovery problem
chek ur bios setting may be if there is recovery key just use that othewise download form the net.
1helpful
5answers
Acer orbicam problem
I have an "aspire 5572WXMi" and i'm having the same problem as karolpalika.. Whenever I open my acer orbicam application, it says "a webcam was not found or is not working properly" help me please...
Reinstall original acer instalation
you can run recovery using the recovery discs which should have been created by you... or you have to go into the OS to access recovery manager...
2answers
Webcam is not working i deleted the software,i have no got software to start t
no funciona mi acer orbicam, el modelo de ordenador es,
acer aspire 9301 awsmi,
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
