Question about Toshiba Computers & Internet
Hi, my satellite pro laptop is powered up. I can not shut it off.
  • 60 Answers
If the laptop does not shut down if you go to Shut Down, you can try pressing the power button and see if it shuts down, if not, hold the power button down for 5 seconds and it will power off.
Posted on Jun 24, 2008
My satellite pro A 300 shuts down when pluged into AC power
The power adapter needs to be checked or better still sub out with a second power supply.
May 14, 2012 | Toshiba Satellite Pro A200-EZ2204X...
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite PRo L300 won't shut down.
SIMPLY REMOVE BATTRY AND POWER SUPPLY
reconnect them
go to power options and check setting
"when i press power button"
select shutdown
May 05, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
After shutting down display buttons remain lit
are you shutting down using the power button? It may be programmed to do another action ( standby or hibernate ).
start menu > control panel > performance/maintenance > power options > advanced tab .
Oct 14, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
What is the power button for toshiba satellite pro 4600
hi..the power button is available on the top
of the laptop.It willl be indicated with the
red symbol on it.
check this out..
thank u..
rate me..
Feb 21, 2009 | Toshiba Satellite Pro 4600 Notebook
Computers & Internet Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
