Question about Microsoft Xbox 360 Console
Xbox 360 not sending signal to TV
We were playing the xbox 360 and it was a brand new game (Bourne Conspiracy), the graphics went like a really bad cartoon? and the next time that we tried to turn the xbox 360 on it just would not send a signal to the TV. Any suggestions????
  • 5 more comments
  • jamison007 Jul 24, 2008
    same issue, game colors on the tv went crazy, then before ya know if no signal. the tv works fine etc. Anyone have this issue with the xbox360?
  • Anonymous Jan 16, 2009
    exactly the same problem, no signal from my 360 to telly, its intermittent however
  • summersadog Mar 23, 2009
    i was playing a game and the colors went really red and a three dimention photo without the glasses. Turned it off and the next time I turned it signal to t.v.
  • Anonymous Apr 08, 2009
    Exactly same problem i was playing moto gp 06 and it happened. :(
  • Anonymous Apr 14, 2009
    my problem was exactly the same, i was only on it for about half hour tops on blue dragon, it was well ventalated, not on or under anything
  • Anonymous Apr 23, 2009
    have same problem..
    "no signal" keeps popping up randomly on my tv, im assuming its the crappy MS xbox causing the problem... (time for my FORTH xbox then?!)
  • Anonymous May 11, 2009
    tv won't read xbox 360 signal. use to us HD setting, now no output works on any tv.
  • 3 Answers
Did the xbox over heat?
Posted on Jun 24, 2008
Having the same problem, did you ever find a fix?
Posted on Sep 04, 2008
Xbox game will not play on my new xbox 360
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Feb 28, 2010 | Microsoft Xbox 360 Console
Xbox 360 problem i have lines in the graphics only
u have a melted graphics chip send to microsoft n tellem u have the 3 rings and theyll fix it
Jan 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 no video but sound
My Xbox 360 video and sound went out and It is not the cord because I used another cord and it still did not work. I was playing a game and the graphics went to really good to bad and I reset the Xbox and know it just comes up with black screen with lines on it.
Jul 26, 2009 | Microsoft Xbox 360 Console
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
Graphics messed up,xbox 360
your av cable is broken i had the same problem
Apr 19, 2009 | Video Game Consoles & Games
Graphics suddenly switches to lower resolution...?
Check to see if you have all cables snug in the individual sockets
and see if you have HDMI, HD Component (RGB cables) or the standard RCA Video Cables (Yellow/S-Video)
check to see if the switch on the cables (standard w/ Xbox) is switched to HDTV or TV.
also, see if you Xbox power is snug, it may cause resets in the Console...(I've had that happen)
Or just try a different video cable/source.
Mar 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 and gh3
Can you play it on your friend's 360 with your hard drive? You could try going on your xbox's memory and delete all of the updates you have downloaded.
Just go to: my xbox-system settings-memory-highlight your hdd and push the y button-on the screen type x x lb rb x x and a message should pop up asking if you want to perform maintenance on your hard drive. If you select yes it will clear all of the updates you've downloaded. Hopefully it'll work then
Feb 21, 2009 | Activision Guitar Hero III: Legends of...
New games for my xbox 360 overheat it.
All of the new games require more work from your graphics card, which without the new heat sync from microsoft, will over heat very quickly. You need to send you xbox to microsoft to have them fix it before you eventually recieve an error code or the 3 red lights or death.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
Xbox- No signal to TV
Before the xbox stop working, the graphics where blurry, or small ojects disappear from the screen. I ask this because it could be GPU that is bad. I remember an xbox that I fix that have a similar problem, when you put Final Round, the fighters on screen disappear or their legs or hands disappear. That occur because the GPU didnt have thermal paste on the heat sink and it was causing overheating.
Aug 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,531 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
