We have a RCA L32WD12 and it will not pickup any channels or select any video input signals; I could hear some sound. The screen lites up and you can select all the menus. I suspect that the (Part Type: PCB SCALER BOARD Part Number: 2147499B) is bad or I have a power supply issue. What do you think and/or where can I get schematics and trouble- shooting guides? Thanks Ollie
I am having the same issue, have you found a solution for this yet?
Posted on Apr 03, 2010
Hi I have a l32wd12 r a TV and it will not turn on
If the clock is on then the unit is receiving power; maybe the external input feature (which tells the TV which outside source to display on the screen, e.g. cable TV, DVD player, VCR player, etc.) is not set to display the TV channels. On my Sony TV there is a button that displays TV setting options (e.g., Favorites, TV List, External inputs and settings). The external inputs function displays the options as video 1, video 2, etc., right up to video 6. My video 3 is for the VCR, video 4 is for the DVD, and video 5 is for the cable TV channels. If the TV is set for say video 3 and nothing is playing on the VCR, the screen will be dark (almost as though the TV is off). Your solution might be as simple as choosing the right external (video) input for the TV to receive the channel signals.
Sep 19, 2014 | Televison & Video
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input).
You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through.
If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct)
Hope this helps.....
Jul 02, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
I was given an rca hdtv model L32wd12 by my boyfriend he had never used it at his house but the person he bought it off of used it. I can not get the tv to do anything but turn on to a blue screen and turn...
I am not an expert but I would guess the tv is broken.
The set might need retuning to receive programmes from an aerial but that would necessitate using the remote to select the main menu. If the menu cannot be selected it is a big clue...
When a signal is injected through an HDMI port or similar the tv should respond automatically. If it doesn't respond I believe that is another clue the tv is broken.
You could make sure by downloading an instruction manual just to be certain you are doing everything right.
Sep 26, 2017 | RCA L32WD12 32 in. LCD HDTV
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
D61w20 with sound and no picture
being able to see menu or osd as it called means that your crt are working.. you have high voltage.. and that you can hear the channels means at least part of the tv is functioning...just the video signal is not reaching the crt's somewhere the signal is blocked. try using a different input.. run it through a vcr. or dvd player and switching input through your remote.. let me know what happen.
Dec 08, 2007 | RCA D61W20 61" Rear Projection Television
No picture with vhs
Don't pass the video sample through the Onkio.. Use a second single RCA patch cord to go from vcr to TV... Use the same yellow out on the vcr that you're using now and send it directly to the yellow video input you're using on the TV..
Hope that's clear - I'm getting tired...
Bill
Dec 02, 2007 | RCA TruFlat 27F520T 27" TV
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Electro Med Services...
