Question about Onkyo Audio Players & Recorders
My Onkyo tuner does not retain the preset station settings when I turn it off. Sounds like it needs a new battery to me. If so, is it something I can fix myself? And where would I find the battery?
You must put the on-of button several times on and of to activate the internal battery charge system.
I have had the same problem, its works!!!!!!!
Posted on Apr 26, 2009
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
How do you se a radio station and preset it on a 2011 elantra. We have preset stations but every time we stop the car the stations are not preset, we have to do it over again.
Did you put an aftermarket radio in the car? If so, it sounds like the yellow wire is not going to a constant power source. The yellow wire needs to go to a source that still has 12v when the key is turned off to retain memory for the clock and presets.
Aug 24, 2011 | Car Audio & Video
RE: OnKYO CR-305TX CD RECEIVER Why do the "saved"
There shouldn't be a battery inside but a super capacitor that is supposed to keep the station memory...may be the capacitor is defective...it should be located on the tuner/radio board and may have a high value such as .47Farads at 5 volts...you may need a tech to replace if you have no working knowledge of circuits , but if you do , you should be able to obtain one at radio shack...they sometimes call these capacitors memory backup capacitors
Apr 27, 2011 | Onkyo Audio Players & Recorders
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
I want to reset the preset stations
To reset or set the preset station you want you need to do this 1 press tuner/band to select the band 2 Press the << down or >> up to tune to desired station 3 Press the  set to stor the station the preset number begining with one appears display you cannot stor a total of 32 preset stations if you need more information check out the manual here .. Manual
Dec 02, 2009 | Aiwa NSX-AJ500 CD Shelf System
Onkyo tx676 loses its preset radio stations when switched off.
No battery, but there is a 0.1 F supercap on the main board that acts like one. Look for C8007.
Sep 14, 2009 | Onkyo TX-DS777
Pioneer premier deh-500ub presetting stations
Storing the strongest broadcast
frequencies
BSM (best stations memory) lets you automatically
store the six strongest broadcast frequencies.
1 Use MULTI-CONTROL to select BSM in
the function menu.
2 Press MULTI-CONTROL to turn BSM on.
The six strongest broadcast frequencies are
stored in the order of their signal strength.
# To cancel, press MULTI-CONTROL again.
Tuning in strong signals
Local seek tuning lets you tune in only those
radio stations with sufficiently strong signals
for good reception.
% Press LOCAL repeatedly to select the
desired setting.
FM: OFF—LEVEL1—LEVEL2—LEVEL3—
LEVEL4
MW/LW: OFF—LEVEL1—LEVEL2
The LEVEL4 setting allows reception of only
the strongest stations, while lower settings let
you receive progressively weaker stations.
You can also perform this operation in the menu
that appears by using MULTI-CONTROL.
Selecting alternative frequencies
When the tuner cannot get a good reception,
the unit automatically searches for a different
station in the same network.
1 Use MULTI-CONTROL to select AF in the
function menu.
2 Press MULTI-CONTROL to turn AF on.
# To turn off, press MULTI-CONTROL again.
! Only RDS stations are tuned in during seek
tuning or BSM when AF is on.
! When you recall a preset station, the tuner
may update the preset station with a new frequency
from the station’s AF list. No preset
number appears on the display if the RDS
data for the station received differs from that
of the originally stored station.
! During AF search, sound may be temporarily
interrupted.
! AF can be turned on or off independently for
each FM band.
Apr 20, 2009 | Car Audio & Video
CR-H100 CD/Tuner/ Amplifier. New about 5 years ago. Tuner won't retain presets. Despite following manual's instructions on both auto and manual tuning, the preferred programme settings are almost always...
These resceivers have a bulit-in device to retain some electricity to feed backup memory. It can be a battery or a capacitor and I think they have reached their time to be replaced.
Nov 21, 2008 | Teac Audio Players & Recorders
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to onkyousa.com or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Can't set the tuner radio stations
After finding the station press the memory button and then the station preset you want to save it to.
Nov 19, 2007 | Onkyo TX-8511 Receiver
177 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
