Question about Kenmore 62622 Microwave Oven
KENMORE MICROWAVE (HOUSEHOLD) LOCKED
KENMORE MICROWAVE LOCKED,
MODEL NUMBER 721 626 22200
The microwave locked while it was heating up food and i attempted to "stop" . It "locked" while I was pushing stop. Now the microwave reads "LOCKED" and now every few minutes it beeps twice.
I would appreciate the help.
Thank you!!!
  • Anonymous Mar 23, 2009
    Solution #2 works!
  • Kenmore Master
  • 9,098 Answers
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
Press START, then Press and hold 0 for 4 seconds.
Posted on Sep 08, 2008
  • glasgavlen Jan 01, 2011
    I have a different model # 665 .60619000 - slightly different method, you simply press
Model FGMV174KFB everything works but food doesn't heat up?
Could be an open internal fuse, failure of the door interlock or control panel failure. Add magnetron failure as another possibility.
Sep 25, 2017 | Microwave Ovens
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Kenmore microwave oven model 721
On the link below is the list of Kenmore microwave oven model manuals starting with 721.Click on selection to download.
www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+micicrowave%2Fhood+combo+-+7218924680
Hope this helps.Thanks!
Jan 07, 2012 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
Kenmore model number 721.80593400 everything works but will not heat food it also sounds louder. I just replaced the magnetron and that did not help any ideas.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | Kenmore 80012 Microwave Oven
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 62622 Microwave Oven Logo
1,304 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
