Question about Whirlpool Dryers
Whirlpool geq9800 fails to heat.unit powers up, but never gets warm. Is there a fuse? Or is it the heating element.
  • 57 Answers
You most likely need a thermo fuse kit. when you get that replaced clean you link tube from dryer to outside of the house
Posted on Jun 24, 2008
My whirlpool duet dryer isn't getting warm
AnneJ EXPERT July 03, 2012
I can understand how important it is to have your dryer working properly. However, without the model number, I can only provide some general information on the issue. There are several components that can cause a dryer to stop heating. These depend on the source of power that the dryer uses. If the dryer is electric the problem could be caused by a failed thermal fuse, hi limit thermostat, control thermostat, thermal cut-off, or heating element. This could also be cause by a blown household breaker (there are two for this type of dryer, and one can blow or pop without the other one), or a failed timer. Some of these will also cause a gas dryer to stop heating, such as the thermostats, the thermal fuse and the thermal cut-off depending on your model. However, there is also the ignitor, the burner, the safety valve, or the coils that can cause it as well. In order to determine which part is causing the problem you will need to test the different components. If you could reply with your model number and any additional details about this, I can then provide a more detailed answer.
Oct 18, 2012 | Whirlpool Dryers
Whirlpool WED5100VQ1 does not heat
Those fuses and thermostats can be checked for continuity with a multi meter. There are several other things that can cause a dryer not to heat. Heating element, burnt wires, improper voltage, inadequate venting, timer, and motor
Nov 03, 2017 | Whirlpool WED5100VQ Electric Dryer
My GEQ9800 dryer will not start. Start relay switch is good, timer is good, thermal fuse is good, door switch is good, input power is good. Nothing happens when you hit the start switch.
Is it plugged in. Seriously,
what about the heating element, have you tested it?
here is a link to replace it if it's bad
Sep 30, 2011 | Whirlpool Dryers
There is no heat on any setting
If you have a power meter and can check the continutiy of the heating element and the thermal fuses that is what you need to do.
Unplug the unit and then remove the back panel remove the wires to the heating element and check for continuity if it has continuity then reattach the wires then look up higher on the side of the can and you should see a high limit thermal fuse remove those wires and test it if it fails replace it.
If you don not have a meter then you might have to remove the element and visually look at it.
as far as the high limit thermal fuse with the wires disconnected you may be able jump them together and plug the unit back in and it should get hot.
this should help solve your problem.Good luck and Happy New Year.
Jan 01, 2011 | Whirlpool Inglis IP8200 Dryer
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
Whirlpool oven will not pre-heat properly
There is an element that circles the rear fan, this is the common element and the most powerful.
Once you have the lid off, it's quick to test continuity on all elements.
Hope this helps
Aug 27, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool Dryers
Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Dryers Logo
170 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
