Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due
to a short inside the igniter circuit or due to moisture present on the
ignition switch.Turn off the gas supply immediately and also unplug it from the
mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between
the igniter and the burner base is too large. *Should be approximately the
thickness of two dimes.
2) Soiled igniter or
burner base.
The above can be tested by switching the suspected burner
with a known operating burner.
3) Loose wiring
connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched
igniter wire between the burner and module.
Both of the above are physical inspections under the main
top.
5) The module may
have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
