Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
GE upright freezer
The top shelf area of the freezer freezes hard but the rest of the freezer does not. I have defrosted and cleaned it out totally and then turned it back on. It seems to have the same problem. Top freezes, bottom area cold but not freezing.
  • Anonymous Mar 30, 2014
    bottom half is freezing top half is not freezing
    Novelist:
  • 161 Answers
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Posted on Jun 30, 2008
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Frigidaire upright model ffu21k2cw1 frost on top shelf and not cooling properly
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/216802800en.pdf
Your unit is not self defrosting so I would suggest you do a manual defrost and see if it corrects the problem.
Also make sure that you have good air flow across the compressor.
Jan 01, 2012 | Frigidaire Freezers
Things don't freeze on the top shelf right hand side of the door. Also have small amount of water that drips after freezer is opened. This is a manual defrost freezer 20 cu foot freezer
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
Jun 15, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not frezzing
DR....let's go down the list:
First is freeze up. This happens when too much humidity gets into the unit from the air and forms ice on the coils. Defrost the unit using warm air or leave it open and off for two days.
Problems that cause this: high humidity, 'window shopping', unit not left closed or bad gasket. If the gasket looks damaged, it will need to be replaced. Gaskets that have accumulated dirt don't seal. Use a mild cleaner to fix this. If you have doubts about an area where the seal is questionable...use a sheet of paper about 2-3 inches wide, close the door and pull it through. No resistance indicates a poor seal.
Make sure you clean out the condenser...the coils where the heat is rejected by the unit.
It is possible that you have refrigerant or defrost timer issues. To check for low refrigerant, start the unit after defrosting it. Note that the larger pipe attached to the big black thing....the compressor...will start to frost. It should then start to form ice while the unit is running...about 5 minutes. If the frost stays and the pipe is not REALLY cold, you have a problem with refrigerant. Sealed units are warranted for 5 years. Defrost timer issues are best left to a tech.
Dec 02, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
395 people viewed this question
Top GE Freezers Experts
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you a GE Freezer Expert? Answer questions, earn points and help others
