Question about Maytag Atlantis MAV6451 Top Load Washer
Water in clothes
Maytag will not spin the water out of clothes
  • 95 Answers
Check the door switch for damage. Use a small jumper wire across the switch, if it spins the water out, you need to get a new door switch
Posted on Jul 11, 2008
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Excess water in clothes at end of spin cycle
May 15, 2009 | Maytag Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
