Danielle steel perfect stranger is defective. In the middle of the movie it stops. If i press on forward it goes to the end of the movie. we miss all the movie
    Scholar:
  • 135 Answers
That happens with some -not all-Dual Layer recorded/store bought DVDs. It probably says so on the DVD case.
Posted on Jun 24, 2008
Where can I get a list of all of Danielle Steel books?
google --danielle steel ---all of his published works will be on a site
Sep 26, 2017 | Tablets & eReaders
Casio dw-290-t, springs came out when changing battery, I know wher 1 goes not the other?
The smaller spring is steel with gold plating. It goes into a hole that is near the outside diameter of the battery. You must remove the outer steel retainer to see the hole. Leave the other parts assembled. They will be loose at this point. When you look inside the hole you should see a gold bottom which is really a contact on the board. Insert the spring with the smaller diameter end into the hole. If you have the correct hole then the larger end of the spring will fit just perfectly. Assemble the outer steel retainer. Finish assembly.
Next time you replace the battery only remove the battery strap and leave the other parts intact. Good luck.
Jun 22, 2012 | Watches
I bought a Samsung BD-C6500 to play MKV movies, it does, but the player stops right in the middle of the movie, so I have finish watching on my computer. Any solution ?
It sometimes does it on certain Mkv movies you will notice it will be the ones you cannot fast forward ,it does it on 2 of the other players try it from the begging
Oct 30, 2010 | Samsung BDC6500 BluRay Player
How do you start a movie from the beginning after you have started watching it, and then stopped it? Even if I remove the disc and reinsert it, it starts where I stopped rather than at the beginning!
Before the movie loads select the DVD icon and press triangle. Scroll down to Start from beginning.
Also, you can go to the disk menu with Square (or menu/title if you have the remote) and go to scene selection and pick the first scene.
Or, you can fast forward through to the very end and the movie will reset.
Sep 18, 2009 | Sony Playstation 3 (PS3) Console
The back light goes off after the logo comes on. I cannot see the menu, the files, etc. They are there--if I go through the motions, I can hit or miss what I want and sound comes out. But it's not the...
It will be hard to see, but go to the menu, Go to settings, Display, Backlight. and set it to how long you want it on since the last time you hit a button. If I'm right, when you get there, it should be set at always off.
Apr 07, 2009 | SanDisk Sansa m250 MP3 Player
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
When I am not pressing on the gas pedal, the oil pressure guage flickers between low and high very fast. As soon as I press on the gas again, it goes right back to the middle (This is normally only after...
The gauge issue is most likely a defective oil sending unit( or pressure ) switch.. No biggy.. They usually run less than 20.00 and labor of approx. 30 min.. Your vibration issue could be a number of things.. You'll need a Tech to test drive it.. could be the brakes rotors.. but not sure..
Mar 08, 2009 | 2003 Ford Ranger Regular Cab
Can't forward to a scene in the middle of a movie
When this Sign comes up it means that you cannot Forward.
You usually get this at the start of some dvd movies.
It is basically to stop you forwarding through the advertisements.
Ive never (YET) seen this (Logo) in the middle of a film denying you to Fast-Forward to a particular point or where you SHOULD be able to select a scene.
I can only presume this Film you have is either a pirate(IM NOT suggesting that you deal with pirate copies)
or a foreign movie.
Dec 23, 2007 | RCA Universal Remote Control
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
