Question about Dryers
Whirlpool Cabrio gas dryer - just installed - completely level - VERY NOISY!
  • 135 Answers
That is a vibration from the idler pulley and spring assembly. It is a known problem by whirlpool. They have a kit out that fixes the problem. Call whirlpool for warranty service and they will come out and install the fix.
Posted on Jun 24, 2008
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Gas Dryer wont stay lit.
It may be your dryer vent piping. If the piping from the dryer to the outside of the house is clogged with lint (which happens periodically) the dryer cannot get rid of the heat generated by the gas burner. When the temperature reaches a certain level the high limit switch opens and shuts the burner off. The switch closes again after the dryer cools down. Check the lint filter and all the vent piping for any obstructions and clean out thoroughly. This should solve your problem. Hope this helps.
Jan 14, 2014 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
My whirlpool model no 6alsr72 washing machine makes a knocking sound on agitation
remove any clothing restart empty run cycle if still knocks its needs to be re leveled
Feb 06, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool cabrio dryer is making a loud knocking noise
Check to see if one of the paddles are lose in the dryer drum.
Nov 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Wed9600tao
Check gas supply, check gas valve, and check igniton system for functionality. Did air get purged from line after the installation? If not, and this is the first use, purge the lines as the installation manual indicates.
Feb 21, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Cabrio model WGD6400SW gas dryer runs but not heating at all. have cleaned it.. still no heat. This happened the same day we had a service tech look at our cabrio washer. Have not had them for 3.5 yrs...
I agree. It's rotten to have someone check out your product and then have it stop working. You probably have a problem with your ignition panel.This is the part of gas dryers that gets hot. When it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool cabrio gas dryer is not heating. it is just a little over 1 year old is there a reset button for the ignitor what is your recommendation it dryed the sheets until they were damp to the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryers Logo
201 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
