0154 0190. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
Try this link too http://remotesearch.blogspot.com/
download you code www. fitness.manualsonline. com and reset the codes. 2) and download the instruc. manual for to proceed how to do it. 3) change the batteries by new ones with alkalines 4) clean contacts batteries 5) Retigh the springs contacts with pliers very well 6) Try again... 7) If there the problem remain, you must open the remote for clean the keypads from dust, and oxide. or go to the repair shop.
If none of the codes in your manual work then you have to do a manual search for the code that will work. Here are the steps to take.
1) Turn on your TV.
2) Press and hold the TV key and while pressing it also press the OK key for one second.
3) When you release both keys, all of the function keys will flash and then the TV key will stay on.
4) Press the power key repeatedly until your TV turns off. Then press the OK key to save that code.
5) You will know that the setup worked correctly if the TV key light turns off.
If you try the above procedure and your TV doesn't turn off, then your remote is not capable of controlling your TV. At that point you can look into purchasing one of the better universal remotes that should control all of your units. Check with the manufacturers webpage to ensure that any remote you look at will control everything you need it to do.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control. 2. Locate a 3-digit code for your device. (000, 031 & 032 for example) 3. Press and hold the corresponding button on the remote control (CBL) for approximately three seconds. The POWER INDICATOR illuminates. 4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off. 5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
1. Turn on the device with which you want to use the remote control. 2. Press and hold the corresponding button on the remote control (SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode. 3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode. 4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off. 5. When the device turns off, press any key to store the code. 6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected].
