Question about LaCie Computers & Internet
Having problem with external hardrive when I click on Lacie Icon.. Error message is- The drive or network connection that the shortcut 'Shortcut to LACIE(E).Ink" refers to is unavalilable. Make sure that the disk is properly inserted or the network resource is available, and then try again.
    Novelist:
  • 121 Answers
Try clicking on the my computer icon and then see if you can see the external drive in the my computer window. Most likely since it is an external drive the drive letter could have changed. If you see in the shortcut before it said E it could have a different drive letter now. Keep me posted and if you found this solution helpful please rate it. Thanks - Tech101
Posted on Jun 24, 2008
  • 3,940 Answers
Open MY COMPUTER
See if the USB drive has been assigned a different drive letter. Or for that matter, is the drive being detected.
When I click on my icon(which has a ? mark on the side) this message comes up. The drive or network that the shortcut TREKSTOR (E).Ink refers to is unavailable make sure the disk is properly installed or...
If you don't have the Trekstor, then just delete that ICON (the one that causes the problem when you click on it).
Or, find the Trekstor, and connect it to your computer, and click the ICON.
Dec 31, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Is the Samsung Zirez Pleomax 80GB Portable Hard drive compatible with Mac's. Reason being that my inspirion laptop now doesn't recognized the portable drive. Worse case if the drive is faulty is there a...
Yes, the portable harddrive is compatible with a MAC Product Features
  • Quick & easy to install Features USB 2.0 &1.1 interface connections allowingit to freely switch roles as local storage device
  • 2.5-inch External HDD
  • Fast & Small 480 Mbps for high-speed performance and smooth data transfer Ultra-slim attractive design everybody wants to have
  • Compatible with PC, Mac & Linux
  • Portable Carry & use either at your desk or on the go Simple & convenient plug & play automatic recognition
http://www.amazon.com/Samsung-Pleomax-Zirex-Portable-UHD2-5-80G/dp/tech-data/B000BB69AS/ref=de_a_smtd/179-8912138-6919333 This error is probably caused by a bad shortcut. The ".Ink" you refer to is really ".lnk" (the first character of the extension is a lower-case "L," as in link, not an "I"). Shortcuts use "lnk" as their file extension.
This kind of thing can happen if you install software from a networked drive and then later detach from that network, which is a common situation if you use a laptop computer that you disconnect from your office network and take home. To find the shortcut, follow these steps: Open Windows Explorer and press Ctrl-F (hold down the control key and press F) to bring up the Find dialog. Select "Local Hard Drives" in the Look in dropdown, and enter ".lnk" (or whatever the error message reported for the name of the bad shortcut) in the Named field. When you click the Find Now button, Windows will search your hard drives for the shortcut and display what it found.
Jan 09, 2010 | Samsung Zirex Pleomax 80GB Portable Hard...
1 TB EXTERNAL HARD DRIVE
Go into My Computer, look for the drive.
Right click on the Drive, click on Create Shortcut you will be asked if you wish to place shortcut on the Desktop instead. click yes.
A new ICON will appear on the desktop, to access the new drive you only have to click the ICON of the drive and it will open....
Jul 01, 2009 | Western Digital Computers & Internet
My laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
May 07, 2009 | Acer Aspire 5920 Notebook PC
Unable to save my word documents when I click on save
If it was truely a shortcut and was deleted, the data is still in the folder on the hardrive (c:) and can be accessed with the file manager or exploring the c: (root) drive. once you find it , right click on it , select "make shortcut, then drag the shortcut to your desktop.
If it was a folder (not a shortcut) on your desktop that was deleted, you should be able to find the folder in your Recycle Bin and select it and click on RESTORE and that should put it back where it was .
If it was a folder and deleted and the recycle bin was emptied, it is lost unless you pay someone HIGH dollar to retrieve data from your harddrive that was deleted.
Hope this fixes ya up , post again if you need further assistance.
Regards..
Apr 09, 2009 | HP Hewlett Packard Pavilion A6200N PC...
Whenever we click on the MyBook icon a message pops up that says: The drive or network connection that the shortcut "Shortcut to MyBook" refers to is unavailable... So I go to My Computer to try and access...
Type in the address in the bar above:
 http://www.         ???
delete the shortcut and make a new on after you get to where you want to be.
Jan 17, 2009 | Computers & Internet
LaCie PC
Try to put hdd in ( for whillem 74) another EXTERNAL!Or just buy new external then put hdd in new external.There is no way to repair it i think!!!
For Fiddler 51 Try hdd in external if it wont acept also then hdd is damanged!
Dec 04, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Brick connection is not registering
It sounds like that brick fell. All bets are off when a hard drive falls or receives shock. Put your ear to it and see if it is making any strange sounds.
Keep me posted.
Nov 21, 2006 | LaCie BRICK (301063U) 300 GB Hard Drive
Computers & Internet Logo
66 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
