Question about Whirlpool Microwave Ovens
VENT CAME ON BY ITSELF. WHIRLPOOL MH6130XEB-2
  • Whirlpool Master
  • 9,098 Answers
The hood / vent fan is controlled by the keypad, but it will also come on when the temperature of the hood area / stove top gets too high.
If it does not go back off by itself after a few minutes, then you probably have a shorted hood fan thermostat.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
How do I change the bulbs
you have to take the top cover off and youll see it right there few screws only
Jan 31, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
My Whirlpool microwave model MH6130XEB-1 made a pop noise and now will no longer heat food. Everything else works fine, clock, timer, fan, turn table, etc. Is this a fuse problem?
It can be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 27, 2013 | Microwave Ovens
My microwave sounds odd and won't heat food. What is wrong?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
There is a clicking sound and the food is not heating
Basic
heatman101
l;ll
Feb 02, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
I have a whirlpool OTR microwave model MH6130XEB, and have lost all power. There is power to the microwave, but the microwave will not come on. Any ideas?
Call a service guy or if you are up to the project, remove the unit from the area and open it up.
Near where the electrical come into the machine.. there should be a circuit board that may look black because it burnt itself out.
Remove this board and replace it, Put back MW and turn it on
Jul 25, 2010 | Whirlpool MH6130XEB/Q Microwave Oven
I need the dimensions of the Whirlpool MH6130XE microwave to insure the opening is sufficient.
You can download the owner's manual and installation instructions here.
They'll give the dimensions.
Jul 23, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
I replaced the bulbs in the underside of the microwave but the lights still won't turn on, can someone tell me what i'm doing wrong or something else I need to do? It's a whirlpool model # MH6130XEB-1
You did not say if the machine works otherwise.
I gather you replace the bulbs in the ventilation section;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260489
Click on the diagram 8 in the left-hand side for ventilation for those bulbs.
Is it plugged in ?
You can check.
Line Fuse
Thermal Fuse
You can find a diagram at;
Click on the diagram 5 in the left-hand side for interior parts and another bulb.
You can check;
Switch;
You can take a voltmeter and place it on the bulb contacts and see if voltage is present when the machine is switch on.
May 09, 2009 | Whirlpool MH1170XS Microwave Oven
Microwave doesn?t turn on
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problerm on the control circuit board. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 15, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool Microwave MH6130XEB
If it's the cooling fan inside the main body of the microwave, I would suspect an open thermistor / temperature sensor. If it's the vent fan (for the grille across the top) then I would suspect the hood thermostat is shorted. The oven should have a "mini-manual" (tech sheet) inside, usually in the control panel frame behind the door open button. It shows these parts and how to test them. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 24, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
