Question about Cuisinart DGB-600 Coffee Maker
Will not brew full pot
The machine will only brew about 2-3 cups at a time and takes 3 to 4 times to draw all the water from the maker. The 2-4 cup button is not on but we have tired it in every poistion. Same problem - brews about 2 to 3 cups from a fill of 10 cups. I have removed the bottom, disconnected hoses, made sure both hose paths were clear (blew compressed air through them, ran water through the resevoir with hose disconnected and it ran through just fine) and ran a rubber "snake" through the heating element's water path. The entire path was "free flowing" yet the problem remains? Cuisinart is supposed to be a quality product. I am having my doubts...
  • johnsimonick Aug 10, 2008
    My post was "The machine will only brew about 2-3 cups at a time and takes 3 to 4 times to draw all the water from the maker. The 2-4 cup button is not on but we have tired it in every poistion. Same problem - brews about 2 to 3 cups from a fill of 10 cups. I have removed the bottom, disconnected hoses, made sure both hose paths were clear (blew compressed air through them, ran water through the resevoir with hose disconnected and it ran through just fine) and ran a rubber "snake" through the heating element's water path. The entire path was "free flowing" yet the problem remains?"
    I would hope to get a more definitive solution than "Regretfully, we have seen this problem quite a lot for this brand of coffee maker. I hope it is still under warranty. This product seems to suffer from trying to do too many things at once. It is supposed to brew a great cup of coffee. But often the full pot does not get brewed. The manufacturer should be addressing this issue. It is systemic."
    Is there someone that can help me diagnose and repair the problem?
    johnsimonick@msn.com
  • Anonymous Mar 30, 2014
    Spills with even 3 cups of water. Water flows/comes out too fast. Dripper can't keep up
    Genius:
  • 1,011 Answers
Dear,
have you checked the setting for cups.
check it by the way..
see keenly in the user manual, the steps that has to be taken for it.
regards,
Posted on Aug 10, 2008
    Genius:
  • 1,665 Answers
See also your manual instructions (page 4)
DO NOT OVERFILL OR THE GRINDER
COULD MALFUNCTION AND/OR THE
COFFEEMAKER COULD OVERFLOW.
http://www.cuisinart.com/share/man/34_man.pdf
Posted on Aug 06, 2008
  • 3,037 Answers
I'll let you in on a little secret. Starbucks has a Very Helpful support line for coffee makers and is known to help consumers that may even own other brands since coffee makers are all basically built the same way. Give them a call at (800) 334-5553 and let me know how this works out
my best to you
  • 2,071 Answers
Maybe the motor is weak already is need to cleaned its motor shafting accumulated a corrosion or dirt already .try this site for more information.
http://www.cuisinart.com/manuals/index.php?item_id=34
Posted on Jun 24, 2008
  • LORETO LACARON
    LORETO LACARON Aug 10, 2008
    to view DGB-600 Coffee Maker click below;
    Coffee Bar Collection
    hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    A clean coffee maker is essential to good coffee. Residue of
    stale coffee oils will interfere the brewing that caused 2-3 cups only produced.
    It is suggest regular cleaning of your coffee maker according to manufacturer
    recommendation.
    I took everything
    out, got a small piece of fine sandpaper, held the plunger in with a pencil,
    turned on the grinder and sanded the round top portion of the grind basket
    driver. It takes a few times to get a good snug fit that’s still easy to
    remove.
    The instruction manual that came with the pot will tell you
    to use one cup (measuring cup) of "white vinegar" and fill the rest
    of the reservoir with regular water. Turn it on and let it perk the mixture
    through the system. Then perk a couple of pots of plain water to flush out the
    rest of the vinegar.
    The books say to do this once a month to keep things clean and the coffee
    tasting great.
    A professional machine that is plumbed into a water supply
    must be thoroughly disassembled, and each part soaked in acid, and manually
    cleaned. Unless your water is exceptionally hard (you should have a water
    softener inline with the machine in hard water areas) this should only need to be
    done every 5 years or so. Heads and screens and filters should be soaked every
    day in a cleaning solution available from any professional machine supplier. A
    machine that is not plumbed should have a small amount of Puly brand cleaner
    added to its tank, and run through several cycles every 3 months. Puly is
    available thru machine suppliers, but there are also several other brands that
    do the same. Visit your local coffee machine shop for a good cleaner.
    Hope this may help;
    Regards,
    VOTIT
    Sergeant:
  • 260 Answers
  • 6,487 Answers
Base from what you've said I think better for you to return this back since it never work fine , because you pay for it so that should work good...You can try checking first again the user manual for that and do the stpes there if its still didn't work have it replace.
Good luck.......
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Codffee Maker
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused 2-3 cups only produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
don't forget to rate there..
Aug 10, 2008 | Cuisinart DGB-600 Coffee Maker
Does not brew a full pot anymore.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Wont brew a full pot
5. make fresh solution and continue process until machine runs full cycle.
May 27, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
142 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
