Question about Kitchen Ranges
GE electric range
It is showing code F7 and flashing d6.
Model # is JSP42WOK4WW
  • birddog1 Jun 24, 2008
    My ge electric range is showing code 7 and flashing d6. What does this mean?
  • Anonymous Jul 20, 2008
    I have the same problem with a jsp42 GE slide in range.
5 Suggested Answers
SOURCE: the lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Posted on Dec 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: oven and control panel not
Sounds like a stuck keypad. Push all pads at random several times each then try it again. If that does not work the clock will have to be replaced.
Posted on Apr 06, 2009
fixyourboard
  • 310 Answers
SOURCE: I have an electric range, model # J SP42SOK4SS.
This means the controller is sensing a stuck key, which may be due to an actual stuck key or a problem with the controller. There is a way to diagnose which is the cause if you are comfortable tearing into the unit, or a repair tech can quickly diagnose for you. If you need a controller, you might consider having us rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
aroracaty2
  • 503 Answers
SOURCE: GE Electric Profile range: Display shows
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 02, 2010
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
F7 error code on GE gas oven model # JGBP90MEA2BC
On this model, code F7 means there is a keypad malfunction, and therefore the range's "computer" isn't getting a valid signal from the keypad. It may be a stuck "touch-key", a bad connection between keypad membrane and the range/computer connector, or more probably a faulty keypad membrane.
In some cases it can be a defective computer module. You can test whether the problem is the keypad or computer unit by disconnecting the keypad entirely. If an error code F7 still shows, then the computer is faulty.
If this was helpful, please rate via the helpful button.
Nov 04, 2014 | Kitchen Ranges
Range is a a JSP 42 GE and is flashing F7 56 D6. Only the burners working. Range has never been used.
Range never used, would suggest it is new, report to supplier, They should supply equipment ready to use, not with problems
Mar 18, 2013 | Kitchen Ranges
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
Alarm sounds and code f7 d6
This error on GE refers to the clock keypad having a stuck button, the only way to repair this is to replace the control.
May 21, 2010 | General Electric Kitchen Ranges
Oven and control panel not working for model # JS900B0K2BB. Stove top is working fine. Panel is flashing some sort of code: F7 and d6. F7 D6. Any help
Apr 06, 2009 | GE JS900WK / JS900CK / JS900BK Electric...
The lcd scrren on my range displays F7 in red and flashes d6 in g
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Panel is showing f7 and flashing e6 57 56 58 5a
GE
Code
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
Keypad Start and Clear are the only keys that work. F7 S6, S7, SA, d6
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control. if problem started while oven was not in use replace key pad
Nov 19, 2007 | GE JSP42 Electric Kitchen Range
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
