Unable to locate my manual...just need help on properly threading the machine.
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
I "might" be able to help you, what is your specific question? email me at [email protected]
HusqvarnaViking "HuskyLock" Serger 431 owners manual
We, Anke Industrial Thread, is one manufacturer and exporter of thread in Anhui Province, China. has focused on sewing thread manufacturing for almost 20 years. Now we have 2 types of products: Bag Closing Thread & Spun Polyester Yarn, with equipped with high-standard machines and strict manufacturing management system, we can supply customers with superior quality and reliability.
Our high quality polyester thread have been exported to various countries and regions in the world for many times, like: Chile, Peru, Russia, South Africa, Kenya, Guatemala,etc.
Over almost 20 years, our thread was widely recognized and trusted by users and can meet continuously changing economic and social needs, all the new and old customers all very welcome, from all walks of life to contact us for future business relationships and mutual success.
Available specification for us:
1) Bag Closing Thread:
10s/4, 10s/5…
12s/4, 12s/5, 12s/6…
20s/4, 20s/5, 20s/6, 20s/7…
20s/2x3, 20s/3x3…
Our location
No.69 Wangjiang Road, Hefei, China 230022
TEL: +86 551 62870071
FAX: +86 551 62870072
E-mail: [email protected]
if you want to know more, you can clickhttp://ankethread.com .
