Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD52725 Hey, Thanks for the post. I have error code 44, but there doesn't seem to be a problem with the DVI cable. I read your post on checking voltages, but I do not know which voltages to check, or what fuses to check (so far, all fuses I checked had continuity). Based on reading these forums, I have checked and verified the following voltages: J9 Pin 1/2 are 5V, Pin3 Gnd, Pin4 12V J14 LampLitz (Orange Cable) has ~2.9V when plugged in, 5V on power up, and then goes to 0V. J14 LampLen has 0V when plugged in. After start up, it will go to 5V for a second or less and back to zero (this is when the entire TV shuts off). With the back of the TV open, I can see the lamp start up for a very short period of time, but it quickly shuts down. Please help, I am trying to figure out if it is the light engine or not. If it is the light engine, I will probably "can" the TV, but I really don't want to do that.
  • Mitsubishi Master
  • 8,617 Answers
I would say the problem lies with the Caps on the Power PCB there are 7 capacitors that fail, and the set wont operate. there are 4 100ufs at 16V 105 defrees and one 2200 uf 35V and two 3300uf 10V 105 degree. they dont always show signs of swelling either, they just fail.
Posted on Jun 24, 2008
How do I fix DVI cable between FMT and Engine disconnected
Are you sure its disconnected? It may have a FMT failure. The cable is inside the back of the TV. you need to remove the rear panel to see it. There should be a white ended cable that plugs in that looks like a monitor wire but short.
Sep 15, 2015 | Mitsubishi Televison & Video
Mitsubishi wd-73739 turns on then turns off with a red constant led
The set has a self check--try this(posted by another expert here):
"Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected"
Jun 03, 2012 | Mitsubishi Televison & Video
Pressed menu and input on front of wd-60735 blinking light 3 times then 4 times
Lamp is first suspect followed by Ballast that drives it.
I also suggest the following answer I posted for a similar set be considered:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
May 25, 2012 | Mitsubishi WD-60735 Projection Television
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Same as jasonvonk mar 15 2010 I get error code 37 after device and menu buttons pushed. red lite blinks 4 short pause and 4 short again Jim
37 is lamp or dmd failure. i don't find anything on 4 red blinks.44 error code which is 4 blinks, and then 4 blinks in disconnected DVI cable from light engine.
Mar 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hi troylove
the dvi cable could be bad in the set or needs to be sited. or one of the boards the dvi connects to. ( would bet it will be the DM board in the Chassis) it will need to be sent off for repair if it is the chassis.
Mitsubishi WD-62327
The error codes are all different for the various models. But your WD62327 is the VK26 chassis DLP heres the error codes and the meaning for your model. Let me know if you need more help.
12 No Error detected, check Power Supply
32 Lamp Cover is open
33 Air Filter Cover is open
34 Lamp abnormality
36 Light Engine (DMD or LAMP Fan stopped)
37 Exhaust or Lamp Ballast Fan stopped
38 Lamp temperature high
39 DMD temperature high
41 Short is detected
44 DVI cable between FMT & Engine disconnected.
May 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
