My combo drive spins the light on the door is lit but, it will not read any type of disk. Is the drive dead and need to be replaced or is there some other type setting or repair?
Is the 'D' drive the cd/dvd drive? If so, try cds or dvds of different types to see what works. Some cd units won't read a dvd. A little light should come on if the drive is trying to read. No light, drive is dead.
If you cannot read those CD-disks in _any_ computer, then the disks are "bad".
If you can read those CD-disks, then it's time to replace the CD/DVD drive. Find a smaller computer-store -- often they will remove the "dead" drive, and install the "new" drive, for $0.00, or for a small fee, if you buy the new CD/DVD-writer from them.
how many types of bootable disks u hav tried,,,if d writer isdetecting d other ones den ur cd is faulty,hav u selected cd drive as 1st boot device or not
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will start
operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but
the TOC (table of content track at start of CD/DVD will not be read,
therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or
Blue ray, or for example only DVD-R and not +R , or only to read and
not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does
not work you will need to disassemble the drive , and clean lens
directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
When the CD does not read any disk, that is usually because of a problem with the
the TOC (table of content track at start of CD will not be read,
When this problem is beginning you may be able to read only CD, DVD or
all.
Try first using a CD lens cleaner disk to clean the lens. If that does
directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems.
Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read).
If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways.
Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks?
If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD.
If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD.
Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
