Hitachi 53SBX59B 53" Rear Projection Television Logo
Anonymous Posted on Nov 27, 2010
I want to remove the screen from my Hitachi Hitachi 53SBX59B 53-Inch UltraVision Projection TV to clean the lamps and mirror. I took the speaker cover off and then removed about 9 screws. I tryed to pick up and pull the screen off and could not. Does anyone know how?
  • Anonymous Nov 27, 2010
    Thank you so much. I did take all the screws out, and my friend tried to pull up on one side and me the other. I wanted to tug on it but my friend thought I would ruin his TV. I know I should just give it a good tap on the bottom to get it up off the brakcets.
    The TV is about 10 years old and in his living room where the fire[place has been making lots of dust over the last ten years. Iasked him when the TV was last serviced, never was his answer. So since we had out TV serviced I watched the technician and thought I would help my friend and do it myself. I will convince my friend that we can get that screen off.
    Thanks much.
Anonymous
Level 3:
President:
  • Hitachi Master 1,779 Answers
  • Posted on Nov 27, 2010
Anonymous
Hitachi Master
Level 3:
President:
Answers
1779
Questions
Helped
579015
Points
5452
I believe on your model the front lower speaker grille pops off, then you will see 4 phillips head screws holding the frame on at the bottom. After the screws are out have someone hold the other side while you using your hand tap upwards from the bottom of the frame evenly on both sides. The frame slides onto slotted brackets on both sides. The frame will lift off, if your control button harness is still attached just set the frame so it is out of your way and not stretching the leads. Clean the mirror with windex and a soft cloth, same with the 3 crt's. If that model has a foil type mirror then be very gentle with it. Don't worry if the mirror has a few streaks left over they wont interfere with the quality of the picture..After reading your post again, sometimes they are buggers to pop upwards.
Testimonial: "Thanks you so much. I will try again."
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
1helpful
Spots on Hitachi 53SBX01BA
green tube has problem maybe bugs if your lucky and lens has to be removed. If your a novice at tv repair call a service center
1helpful
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
2answers
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
53sbx59b Hitachi 53 inch proj tv
Call the 800 number with the new remote. Sometimes they will have additional codes. Or with the instructions with the new remote you can manually get it to work. You must follow instructions carefully. Look for this section in the instruction booklet
1helpful
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
Did you ever find the solution to removing the front screen? I have the same problem. Please write at [email protected]
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
