Question about Dryers
Need to know how to wire a dryer and stove to a bryant type brd bq230-240 breaker. Not sure of order the wires go in. Any help would be great.
  • 161 Answers
The black and red wires go to the screws on the breaker itself and the white and green/bare (there is not always a ground wire) get connectet to the ground strap usually at the bottom or side of the breaker box. It is the silver strip with screws that most all white and bare wires are connected to. If necessary on the heavy stove wire, seperate it into 2 or 3 bundles and use seperate screws. Have the hardware store guy show you how the breakers fit in the box. Dryer needs 30 amp, Stove 50 amp. double pole. (wide breakers)
Posted on Jun 29, 2008
How do I know if the 50 amp manual reset circuit breaker needs to be reset? there is a small yellow lever with reset printed on the top
If the breaker handle is in the middle position, it needs to be reset. you reset it by pushing it to the OFF position and then to the ON position
Oct 29, 2014 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
Bryant BR260-cu2-8- al2-6
You should replace the breaker with the same type and rating
Mar 25, 2013 | Bryant Electrical Supplies
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
I need to replace a 15/15/15/15 Bryant Quad breaker. It is very difficult to find these for sale. Can a quad be replaced with two twins or four single pole breakers?
The reason for using the quad, is so that if any one of them trips, they all trip. GE used to sell lever covers that would join the levers together. I don't know if they still do. And I don't know if the Bryant breaker is JUST 4 single poles with their levers connected together.
Aug 13, 2011 | Bryant Westinghouse Bqc Quad Circuit...
My old Bryant circuit breaker keeps turnin off and cannotr be re-set. It is a type CU 10-14 AL 8-12 What kind of breaker it is and what would I replace it. ZM
The spring in the breaker is worn.Best to shut off main and disconnect breaker,pull out of box and take it to a electrical hardware store.
Home depot and lowes sell many different types.The numbers you gave match nothing i can find.
Mar 31, 2011 | Bryant Electrical Supplies
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
Bryant brd 30-30-30-30 quad replacement
You could get em here :
Why anyone would use a twin 2pole 30am breaker I'll never understand.
There is no way this size breaker could match up in quality to two full size 2-pole 30 amp breakers. If one wants to double up, do it with the 15-20 amp sizes.
Jul 16, 2010 | Bryant Westinghouse Bqc Quad Circuit...
220 appliances in house all out.lights up but either dont heat or wont bake .lightning could be culprit but never lost tv reception.dryer runs ,no heat.water heater out.stove lights up wont get hot.shut...
Sounds like you have lost one leg of your power
Think of it like this
You an upside down "Y" at the top of your breaker panel
220 - 240 volts come in the Y and break in half 120 volts to each leg of the "Y"
A 220 Volt breaker straddles both legs a 110 volt breaker only contacts one leg
I suspect that you have lost one leg
Possibly at the main breaker ( top most)( main disconnect) in your panel
If you have a tester with the capacity to test 240 you can test the two top lugs where the main wire comes in Test them together That is one probe of your tester on each wire you should show 240+/- volts
Then you can move down through the panel 120 +/- on each leg
Hope this helps if you need more just let me know
Mar 16, 2010 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
I live in a mobile home with a westinghouse DP 200 amp main breaker. it trips alot when i run the stove and the dryer along with other items.
You need to run a new circuit to the stove before your electrical wires catch on fire. that is a hazard you have taking a big chance if left alone. Your old wires and breaker is not heavy enough to run both so a complete rewiring job will be in order if not reaired very soon I would say from past experiences I've encountered
Jan 18, 2010 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Dryers Logo
Top Dryers Experts
