Question about Carrier Heating & Cooling
Weathermaker 8000vs circuit board
My furnace blower is not working in the cooling cycle but works in the heat cycle.
Repairman says I need a new circuit board and it's $562 (standard rate) to repair it.
Is there anyway to re-solder a capacitor or some resistors to avoid this huge repair cost?
hotuna
  • 288 Answers
SOURCE: Carrier weathermaker sx 58 furnace
This sounds like a thermal disc or the heat anticipator on the thermostat is not set right. What was the $500 spent on?
Posted on Dec 19, 2007
edgz
  • 26 Answers
SOURCE: furnace blower needs repair
Hi,may be your Fan motor shorted ,pls check the that lead wire of FM.
Regards,
Edgz
Posted on Feb 09, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
SOURCE: Carrier Weathermaker 8000Vs
This is nothing short of a circuit board fan relay of a bad motor.. to find out if the motor is good, unplugg the black & white wire , in which white =ground black=hi-speed 120volts and conect them to power -ground and see if the motor works..if does, then its the fan circuit board if not then its a bad motor...
Posted on Aug 25, 2008
wehrhard
  • 3 Answers
SOURCE: Rudd UGDG-10EAMER Furnace keeps shutting off before reaching temp
If you have a air restriction, like the tech has said, then the system will be shutting down do to the high limit switch. This switch prevents the unit from over heating, to the point of causing sever damage. Before you call that company back out I would let them know that you are not going to pay for another trip because they haven't fixed the problem. Ruud does not have many problems with the control board. They are a die hard breed.
Posted on Nov 16, 2008
Furnaces starts on its own thermostat is off.
sounds like your thermostat is not working like it should. check to see if any wires are loose or broken
Jun 16, 2014 | Atwood 34,000 BTU 8500 IV Furnace
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Blower stays on
It would piont to the afc not working Automatic fan control not shutting off on temp fall .
Mar 29, 2012 | Heating & Cooling
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
The terminals on the control board are designed to provide power to the controls of the humidifier, not run directly to the solenoid. If you don't want to install the controls, you can run the 24 volt signal from the furnace heat signal (W1/W2) through the humidistat to the solonoid. This will allow 24 vac to get to the solenoid only when the furnace is running. I do this on most humidifiers that I install.
Jan 28, 2011 | Heating & Cooling
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Mar 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jul 18, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker 8000 58zav115
see if power is supplied to the gas valve if not replace the valve also should have the heat exchanger inspected before any thing else
Jan 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
126 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
