Question about MTX TA4501 Thunder 4501 MonoBlock Car Audio Amplifier
Help connecting the sub
Im having a problem hooking my subto the amp it sems like irything connected right but i get no action from the sub
  • 109 Answers
Your sub or amp is probably blown. Do you get any power to the amp? try hooking up another speaker and seeing if you get any signal at all.
Posted on Jun 24, 2008
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
My redceiver gives me a message saying "protect" when i turn the volume up. this started after i hooked up a subwoofer, why is this happening?
You should consult the manuals for the receiver and the subwoofer to make sure you haven't connected the sub improperly. If the amp was working normally before you connected the sub, I would look at the sub hookup first. If the sub is a passive type, and you have connected it in parallel with your main speakers, the amp may not be able to handle the extra load. You may have to get another amp to drive the passive sub. If you have an active sub, you may not be using the right input/output connections between the amp and the sub inputs. Or, you may have hooked the sub up in a way that causes the amp to become unstable. Check the manuals. If you can't resolve it, come mback here with a lot more detail about your gear.
Oct 07, 2010 | Harman Kardon AVR 310 Receiver
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
The light on my amp is green but no sound
have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
Mar 18, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Can you please tell me how to connect my kef psw
If your amp has a "sub out" jack, that's the best way to hook up this sub. You'll just need a single RCA (also called "phono") cable. Connect it to the Left input on the sub, which should also be marked as "mono"
If your amp just has speaker-level outputs, then connect the left and right main speakers from your amp to the sub's high-level inputs, and then run wires from the sub's high-level outputs to your speakers.
If you're running a surround-sound setup, use the front-left and front-right speakers for this hookup.
If this helps, be sure to hit the "thumbs-up" button for me!
If not, post back with the "Add comment" and I'll do my best to answer any questions you've got.
Jan 23, 2010 | Panasonic Audio Players & Recorders
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Powers up but no speaker output
Hello montez1599,
That's a great amp.
You do not say what subs you are connecting or what wiring configuration you are using. But there should be no problem if the amp is powering up normally. I'd check the gain and crossover settings to make sure they match the subs.
Having 2 +'s and 2 -'s is just a convenience for connecting more than one sub to the amp. If you have just one sub, connect to either of the positives and either of the negatives (they're connected internally). If you have 2 subs, you can run separate wires to each sub or you can wire the subs together and then run just one positive and negative to the amp.
Hope this helps.
Aug 30, 2009 | Jl Audio 500/1 Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
I need help with a system that I just bought.
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
Mar 12, 2008 | Audio Players & Recorders
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Car Audio & Video Logo
88 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
hoyzee1
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
