Question about LG WM-1832C Front Load Washer
Door latch the call was for. lg front load washer filled to capacity and blow the door open."per customer" but had errror code DE. so I replaced the pressure switch and the door latch, which was broken from visual inspection. replaced latch, you can hear it tring to engage, but will not and getting DE error still. trust me,I triple checked wiring connection, unpluged the unit and also stuck another door hitch in the latch and it's still not engaging.
  • Anonymous Aug 02, 2008
    de code is showing washer will not run flashing de code
    Genius:
  • 3,422 Answers
DE error code is because there is a drain problem and it will not lock the door.
Posted on Jul 11, 2008
  • 1 more comment
  • Priya darshan Jul 11, 2008
    Check if the drain pump is damaged or not.If it is then you will have to get it replaced.
  • Priya darshan Jul 17, 2008
    DE error code is because there is a drain problem and it will not lock the door.Check if the drain pump is damaged or not.If it is then you will have to get it replaced.
    Thanks for using fixya
  • Priya darshan Jul 24, 2008
    please accept the solution.
My de error problem was because the door was tweaked a little and wasn't making the full seal. I put my knee against it and started the cycle with no error. So far, so good.
Posted on Nov 04, 2008
  • 489 Answers
DE error code is because there is a drain problem and it will not lock the door.  You will need to clear out the obstruction in the drain pump before operating the machine.  It is possible that the drain pump could be damaged from excess debris breaking the pump.  In that case, the drain pump will need to be replaced.
Posted on Jun 26, 2008
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
Washer door latch
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Why does my LG washing machine model LG16115FD show error code dE please?
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 10, 2014 | LG WD-16115FD Front Load Washer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
We get a de code
A "DE" is a drain error, but a "dE" is a door error. If it was in storage, I'd look for damaged wire(s) to the door lock switch caused by a mouse. It is less likely that the door latch itself needs replacing.
Apr 12, 2009 | LG WM-1832C Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
DE door switch problem
I bought a switch in Portugal by €7,5 and ...nothing. I bought a drain pump €18 and still not working. I have consult one tecnical expert by phone were i bought the pices and he said tha could be the pwc board (€75). Here in Portugal they quote €25 to come and €30 per first hour...I decided and I bought a new Lg with direct drive but I stored the old Lg (6 years old, without problems, and working 2 times per week)...if you try... and it works tell me ok ? Good Luck.
Oct 07, 2008 | LG WM-1832C Front Load Washer
De is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
LG WM-1832C Front Load Washer Logo
791 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
