Question about SanDisk Sansa m240 MP3 Player
Sansa m250 mp3 player
Computer says it is connected - but devise is not showing up so i can transfer songs
  • yrramu Jun 28, 2008
    it is comming that the usb connected to the computer has malfunctioned i tried pressing the + button for 5-50 seconds but it dint help what can i do
  • 8,596 Answers
Make sure hold/lock is not engaged
if not, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 27, 2008
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
Identifying files in scandisk
I had a similar problem.
This is how I fixed Sansa m250 2GB
I have Windows XP, so if you have a different version of Windows you might have to do something else.
Connect the player to your computer.
From My Computer open the drive that says SANSA M250
If there is no folder called "audio" make a folder named that. (this is where your future mp3 files will be stored).
My audio folder was missing, so I had to do this.
Now go back to My Computer right click on the SANSA M250 drive scroll down the menu and open the folder that says "Open As Portable Media Device".
Now click on the icon that says "SANSA M250"
Now open the folder that says "FOUND.000".
If you are having the same problem that I did all your old mp3 files will show up with a file extension .CHK instead of mp3 and the names will be numbers. You can either erase all these & reload all your songs into the "audio" folder I mentioned previously or you can rename each file extension to a .MP3 instead of .CHK. (after you change them to .MP3 they will load on your mp3 player. But, remember if you do choose to rename them instead of erasing and reloading, when you want to permanently delete them you will have to access the "FOUND.000" folder again to do that.
Nov 20, 2008 | SanDisk Sansa m250 MP3 Player
Sansa sandisk mp3 4 GB player
cannot delete songs off my device!!!!Help Me!!!!!!
Sep 25, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
M250 sansa 2 gig
Make sure hold/lock not engaged
Jun 24, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m250 2GB file adding problems
Can't create directories directly on the m250. I've got about 1000 songs loaded (already broken into subdirectories) that take up 800 MB and the device claims that it's full. (Firmware is also updated to 4.1.08A)
Dec 26, 2007 | SanDisk Sansa m250 MP3 Player
Mp3 Songs are not visible.
Go to the menu in you mp3 player. In the menu, under settings, make sure that "advanced" is set to off. Then it should show that the USB is MSC, not MTP, and you should be able to view your songs when you hook back up to the computer.
Nov 19, 2007 | SanDisk Sansa m250 MP3 Player
Sansa m250 mp3 problem with songs
The device has 2 modes of operation, if you transferred music in both modes, it is not reflected in the other.
Easiest solution is to format the device to remove everything, then transfer your files back to the device, staying in 1 specific mode.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
