Question about ASUS P4V8X-MX Motherboard
Not detecting second dvd drive
I have a cd-rw installed. I just installed a dvd drive as a secondary. The computer does not detect it. Is there a way for computer to detect?
  • 68 Answers
Try going to hardware digonositcs if you have windows vista just press start and type in hardware diagnostics and thats all i can tell you
Posted on Jun 24, 2008
Computer doesnt detect drive
Not exactly The computer detects the drive but windows does not detect the driver. Uninstall the drive in the Device Manager and Restart the computer. This will reinstall the driver..
Nov 29, 2013 | Panasonic (CF-VDRRT1M) CD-RW/DVD-ROM...
Not detect any cd or dvd
Sounds like its not installed properly - check the cabling and power and re-install any drivers as instructed in the manual.
May 27, 2009 | Philips 20x DVD±RW Drive Burner
Dvd rw is not detected in windows xp in my toshiba a75 laptop
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > click on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and select uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 07, 2009 | Toshiba A75-S125 Satellite Notebook
CD Burner not detected.
Check your different jumper settings in the drive; Is your CD RW drive set in the proper setup as a slave or master drive; or as a single drive.Check in your bios, in the disk management section if your CD RW is detected.
Apr 22, 2008 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Dvd-rom icon missing
(1) Check bios for detection if detected continue the following steps else DVD is gone or you can remove test it in other system.
(2) You can manually DVD from control panel by clicking add new hardware wizard, continue the step.
(3) last option try install your operating system agin.
Apr 19, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
HP CD-RW DVD RW COMBO
I HAVE AN HP LAPTOPmag-glass_10x10.gif WITH CD-RW AND DVD RW ON IT BUT WHEN I TRY TO BURN EITHER OF THE TWO IT SAYS DRIVE NOT DETECTED. HOW CAN I MAKE SURE IT IS INSTALLED PROPERLY
Apr 01, 2008 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
CD/DVD Writer drive not detected
is it showing As Drive D:- Or E:- In My Computer ?
Mike @ Compurepair.
Feb 22, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Installing it
hi
may i ask how you installed your dvd burner? is it primary or secondary?
may i suggest that you install your burner as a primary on your ide cable and also, if possible, update your media player so that you can be sure that it will be detected.
you may not need an installation disk for that. because once it will be detected, it would be smooth sailing from there.
hope this helps you.
Jan 20, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Dec 17, 2007 | Computers & Internet
ASUS P4V8X-MX Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
