Question about Philips 60P8341 60" Rear Projection Television
Blurry/Fuzzy Picture/Double Vision after power outage
A storm knocked the power out for a few seconds. The TV came back on fine but the picture is all fuzzy or blurry. All type/print/words shown on the screen are double; almost impossible to read.
  • ADIMEN Jun 25, 2008
    i have the same problem everything works but iy is real blurry
  • thickmrs Aug 08, 2008
    Exact same problem but I did not have a power outage ,not that I know of anyhow unless it happened when I was not home. But I have double vision words and color problems. The tv was working great last night then this morning when I turned it on this is what happened. I have cut tv off and on, tried to adjust the color and also I reset the direct TV also I disconnected the DTV to make sure it was not them but I have same problem on regular TV channels too.
  • 1,139 Answers
Hello stevenkgray and ADIMEN,
I think what has happened is the your TVs are out of focus which could be due to a voltage problem. First I would warn you that this is a problem in the High voltage section of your TV and caution should be taken, in fact I would suggest that if you do not have a background in electronics that you get the TV checked and fix by a qualified TV repair technician. However if you do have a background the next few lines will make sense and you might be able to effect these repairs yourself.
Items needed for troubleshooting:
Schematic Diagram
High Voltage probe (40Kv)
Universal Video Analyzer (UVA)
1) Unplug the TV and take the back off of it
2) connect the UVA to the tuner F connector and setup the UVA to send a test pattern into the TV
3) Power the TV back up and turn to the channel set on the UVA
4) check the anode voltage on the CRT with the HV probe (connected to the Multimeter set to volts and grounded) and compare it to the voltage on the schematic.
5) If the voltage is not right adjust the focus and screen controls on the Integrated High Voltage Transformer (IHVT) to obtain the proper voltage.
6) Check the pattern to see if it is still fuzzy.
If the pattern is still fuzzy you may have to inspect/replace the IHVT and or its associative circuitry.
If you suspect that the IHVT is bad you can perform a ring test on the transformer using the UVA. (The instructions on how to do this are on the UVA quick steps pull out. or the instructions can be looked up on the web.
I hope this helps
Thank you,
Posted on Jul 04, 2008
No picture
  1. 1 Make sure the power cord is properly plugged into a wall outlet if your TV is not powering on.
  2. 2 Make sure the video and audio cables connecting your TV to external devices are secure if you are experiencing a fuzzy picture or no picture.
  3. 3 Reset the parental password if you forgot the password and are unable to view certain programs. To do this, click "Menu" on your remote control and use the arrow keys to select "Parental Controls." Enter the master password, which is "4357" to reset the password.
  4. 4 Turn off the caption vision option if you are seeing a large black box on your screen. To do this, click the "Menu" button and select "Setup." Select "Caption vision" and press the "Plus" button on your controller to set the option to "Off."
  5. 5 Check the "TV/Video" setting if you're not getting a picture on your screen. You may have inadvertently selected a video input that isn't active. Press the "TV/Video" button on your remote to cycle through video inputs.
  6. 6 Alter the brightness settings if you are experiencing a poor picture or no picture. To do this, press "Menu" and select "Video." Increase the brightness settings to see if the picture begins to appear.
  7. 7 Make sure the volume is not muted if you are experiencing a clear picture but no sound. Press the "Mute" button on the remote control to turn mute on and off.
  8. 8 Power cycle your Sony Wega if it's frozen or not responding to your remote control. Unplug the power cord and wait a few seconds. Plug the power cord back in.
Dec 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Fuzzy with double picture
TV is blurry as if expanded, do not know how this happened. Words are blurred, picture is not crisp anymore. Help please.
Aug 12, 2010 | Philips Magnavox 27MS343S 27" TV
My vizio p4 edtv 46" made in 2003, went from working fine to a fuzzy blurry picture. You could change the channel and it would be fine for a second then back to fuzzy and blurry. I hooked my dvd player up...
This is not an easy fix. It's the main board (PCI) which is the board you plug your DVD player or cable line into. You could replace it yourself, but if your not a tech you might want to have a local repair shop do it. You could find the part online. This is an older TV so the part might cost you $300.
The part number should
M/B 4359401414
Jan 04, 2010 | Vizio P4 46 in. HD-Ready Plasma Television
Red lines, blurry picture
try this link. It fixed my sony.
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Blurry picture
If the power to the tv was on when the power came back on it may have caused a power surge through the tv and could have knocked the allinment of the colour tubes out a bit you could try to reallin them via small screws on the colour tubes but you need the tv on an it can be difficult.
Jul 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture looks fine in middle but the sides doubles
zenith 55" projection tv. approx 8yrs old.
the right half of picture is normal the left half of picture is blurry or shows double or triple vision.
Feb 13, 2008 | Televison & Video
Philips 60P8341 60" Rear Projection Television Logo
427 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
