Question about GE Heating & Cooling
When i turn on my air conditioner it keeps going off
It is model number AEW08AJS1 - When I push in the button on the side of the plug it just goes off. The screen says "set". Is there a way to set this?I can't find my instructions that came with the air conditioner.
  • 21 Answers
Go to the GE site and download the maual or go to store and aks them to copy this section for you.
Posted on Jun 24, 2008
WHY DOES MY FRIGIDAIRE AIR CONDITIONER SLEEP BUTTON KEEPS BEEPING?
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
Feb 22, 2015 | Frigidaire Heating & Cooling
The air conditoner will not turn on the remote works but the unit itself wont go on is there a fuse in it
The newer air conditioners have a button on the actual plug. It is a reset breaker switch. Try pushing the button on the plug while it is plugged in. (Assuming it has one)
Nov 23, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Wont start e-1 code
If your AC is a SHARP unit-- here is a place that tells how to get rid of an annoying e-1 code problem-- Sounds pretty complicated! :-)
But keep it around-- for in another 720 hours you will have to do it again!
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready.
Jan 26, 2011 | Heating & Cooling
We have a portable air conditioner. It keeps
Follow the steps below....
panel.
button.
Jun 26, 2010 | Heating & Cooling
My error code E1 won't clear after draining the water resevoir.
I offer the
following procedure to clear the nefarious E1 indication, and obtain
another 720 hours of cooling bliss:
panel.
button.
1-800-237-4277
May 16, 2010 | Heating & Cooling
EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Jul 27, 2009 | GE Heating & Cooling
The error code is saying E1
panel.
button.
1-800-237-4277
Jul 12, 2008 | Sharp Heating & Cooling
Sharp Air Conditioner
This is from Sharp's website...apparently an addendum to the instruction booklet. When you get E1:
Unplug. Press and keep pressing the On/Off button on the unit. Plug unit back in. Wait until unit beeps (about 5 seconds) then release On/Off button. Unplug unit. Plug unit back in.
You're good to go.
Sep 04, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
