Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water line Hi, Is the water line difficult to install? Can you walk me through it?
  • ernurseohio Jun 26, 2008
    Same problem here. Bought a used side by side and have no clue how to connect the water line or if I need to buy a new kit or what.......Help!
  • 828 Answers
If the refrigerator was designed for water there will be a connection in back with a 1/4 inch compression type fitting to connect the water to. You may need to purchase a kit with a saddle valve and 1/4 in hose to route from the saddle valve to the refrigerator.
Posted on Jun 26, 2008
Water pump
Purchase a Haynes manual for your car, it will walk you through the removal of old pump and installation of new pump. Do not purchase a rebuilt water pump, purchase a new water pump, pump gasket and thermostat with gasket.
I have replaced several Chevrolet water pumps, if your car is a front wheel drive you will have to support the engine from the bottom with a floor jack in order to disassemble the motor mount in front of the water pump.
This is not that difficult of a repair but you will need metric and fraction size wrenches and sockets. Since some of your car is built in USA and Mexico or Canada this is how it is.
I hope this helps you! Good luck.
Apr 17, 2014 | 2004 Chevrolet Malibu
How to install the water for the ice maker
To hook up an water supply to an ice maker falls under two catagories. The first being that a water supply valve is already present behind the machine and therefore all you have to do is get a water line, preferably a braided steel ice maker line that can be purchased at home depot or lowes. Then you just sonnect the water line to the water supply at the wall the to the water valve on the machine, located on the lower right or left side in the back. The second scenario is yoo don't have a supply line, and in that case your going to have to locate the nearest water line, most likely under the sink, and you'll have to run a line. They have an ice maker installation kit at home depot and lowes, and you may have to drill a hole through the cabinet to make the line unseen, or even through the floor and back up again. Either way its not a difficult task, just takes time and patience. Good luck.
May 10, 2012 | Frigidaire Refrigerators
YAMAHA 2001 40 HP NOT PUMPING WATER,PUT OUTBOARD DEEP INTO CONTAINER OF WATER,AND FAILED TO PUMP OUT WATER,EVEN AFTER LOW REVS,SWITCHED OFF IMMEDIATELY BUZZER ALARMED
Hi, it needs to have the water pump overhauled and it is not something you should attempt on your own. Take it to someone experienced to have it done correctly. Regards Phil.
Nov 01, 2011 | Light Outboard Motor Boat Bass Fishing...
Audi replaced the radiator support and now claim the electric water pump needs to be replaced
2002 Its due.
Water pump failure is equal to walking.
Plus total engine failure.
Now, does this sound to expensive for a water pump?.
INFO:
It is also due a radiator flush and new belts.
Hope this tip helps you through this difficult decision.
r/
David
Feb 23, 2010 | 2002 Audi TT
No water and no ice
no water no ice...
problem with water line. you installed it yourself did'nt you?haha seen this countless times.I'd be happy to walk you through it.
Sep 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
WHERE IS THE WATER PUMP LOCATED ON A 1998 PLYMOUTH GRAND VOYAGER
Here are the steps required to change the water pump on the 3.0L engine.
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the drive belts. Remove the timing belt covers and the timing belt.
  4. Remove the water pump mounting bolts.
  5. Separate the water pump from the water inlet pipe and remove the water pump.
  6. Inspect the water pump and replace as necessary.
To install:
  1. Clean all gasket and O-ring surfaces on the water pump and water pipe inlet tube.
  2. Wet a new O-ring with water and install it on the water inlet pipe.
  3. Install a new gasket on the water pump.
  1. Install the pump inlet opening over the water pipe and press until the pipe is completely inserted into the pump housing.
  2. Install the water pump-to-block mounting bolts and tighten to 20 ft. lbs. (27 Nm).
  3. Install the timing belt and timing belt covers. Install and adjust the drive belts.
  4. Reconnect the negative battery cable. Fill the cooling system to the proper level with a 50/50 mixture of clean, ethylene glycol antifreeze and water.
  5. Run the engine and check for leaks. Top off the coolant level, if necessary.
Jan 12, 2009 | 1998 Plymouth Grand Voyager
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
61 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
