Question about Canon PC-940 Black and White Copier
Grinding noise The 940 sounds like the gears are not engaging ....or something horrible. I shut it off immediately, of course. I've noticed that the paper drawer has something blocking it about half-way in...if I hold down the spring-loaded piece that pushes up the paper, it will slip in. But, to no avail. when I remove the tray completely, it still grinds away...and I shut it down. I can't see it operating, of course. And, there is no manual that explains such a calamity. Charles A.
    Problem Solver:
Unfortunately, the site does not accept my info. I have no idea why since I use the visa for hundreds of purchases with no problems. All info is correct. Here is the message. If you like, please answer and I'll send you a check should it work out.
*Email Address:
* indicates required fields Please correct the highlighted fields below: Transaction was unsuccessful, Please check your information. grinding noise - pplwait.gif dot_clear.gif
Posted on Jun 24, 2008
Grinding when turning key on to start ignition
Dodges have a gear reduction in the starter, usually. It could be wearing out. Have it checked out at a rebuild shop.
Nov 30, 2013 | Cars & Trucks
I am hearing a grinding noise when turning the ignition on my 2005 dodge ram 1500.Truck is automatic and runs fine when in driving.
Have an auto electrician look at the problem but I suspect that the starter solenoid is starting the armature spinning before the pinion gear is properly engaged in the flywheel teeth. If so the starter can be repaired either by a new solenoid or adjusting the pinion movement before the armature gets power.
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
Lever to start the toaster will not engage consistently and makes a horrible sounding noise. After several tries with different pressure, it will engage. The question is "how long before it will no...
mcdevito75 here, If the lever mechanism is worn it could give out at anytime, the sound you hear is like gears grinding, make sure the setting for Darker / Lighter toast is not set too low, set it for Darker toast and then see if it"s better.
Jun 22, 2010 | Cuisinart CPT-60 Custom Control Total...
Wii makes grinding noise, when disc is inserted, it immediately ejects it, accepts it back in, then ejects it onto the floor while making horrible grinding noises
There is either something inside of your Wii's DVD Drive blocking the insertion of the disc, or some of the gears inside of the DVD drive are damaged. Lots of times, one of the kids will stuff a penny, credit card, or some other foreign object inside of the Wii's disc slot. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
http://store.richspsxparts.com/wiiredvddr.html
Jan 15, 2010 | Nintendo Wii Console
Grinding noise immediately after start up - (starter engaged?)
Sounds like your starter is slow to disengage , but I would check with someone who is handy with cars , not necessarily a mechanic , just someone who can confirm your assessment and my suspicion. If that's the case , you might have to replace the starter. This problem could damage the ring gear on the engine which would be a lot of $ to have replaced.
Nov 04, 2009 | 2000 Volkswagen Jetta TDI
Rear-end grinding noise in 1993 GMC Sierra 1500
your description sounds like the gears inside the the same differential you just replaced.
Oct 13, 2009 | 1993 GMC Sierra K1500
Loud clanking noise in or outof gear if the clutch is not engaged
Sounds like a throw out bearing or pressure plate problem. Run it by a trany shop, and they should be able to tell quick and easily if that's the problem.
Jun 08, 2009 | 2006 Kia Rio5
High pitch noise when turn key to start / engine not turning over
Check your battery first. Cold weather does horrible things to car batteries... if it's more of a grinding sound I would say that your starter gear is bad. I believe they call it a ring gear? I had a similar problem with a kushman scooter that I use to deliver snowcones through the neighborhoods. It has teeth that need to engage and if those teeth have been grinded down it will have a hard time engaging....
Dec 15, 2008 | 1997 Ford Ranger SuperCab
Volvo XC70, Grinding Noise
sounds like c/v axles (front drive shafts) they will make a clicking sound normally when turning sharp and accell at the same time at slow speeds / look at the axle boots and look for grease on the inside of the front wheels leaking out the axle boots
Oct 07, 2008 | 2001 Volvo V70
Canon PC-940 Black and White Copier Logo
85 people viewed this question
old marine
old marine
