Computers & Internet Logo
Anonymous Posted on Nov 27, 2010
I have a problem with IE7 i troubleshoot it and i found out i have 2 files that are totaly missing i find it in system services the files are dlls but it say file missing they are IECONT.DILL and IECONTLC.DILLi know of a site that you can download OS dills but they didnt have these ones i bought pc used and browser was always a little weird but lately its just not right download problems hangs long redirects etc can any 1 help my son is in a online college n its important i get it fixed can any1 help thanks
JASEEL P
Level 3:
  • Master 556 Answers
  • Posted on Nov 27, 2010
JASEEL P
Master
Level 3:
Answers
556
Questions
Helped
128890
Points
2042
For solving your problem
1)reinstall your operating system
ok
  • Anonymous Dec 28, 2010
    it runs good without em i was wondering why they missin it rock solid fast so why reinstall ??
  • Ebuka
    Ebuka Apr 04, 2014
    why not format and reinstall a new OS, you can backup your Files before Formatting.........
Message pops up when I start my computer "the specified module could not be found
a dll file is missing or cannot be found or is corrupt. either way, it cannot be pulled from and opened up. a dll is actually a lot like a executable program and operates the same way, so go to google, type backgroundcontainer.dll download. go to the website that allows you to download dlls. then go to my computer, type in the address bar: %appdata% go to folder localcounduit, then go to folder backgroundcontainer, and copy/paste the downloaded .dll file.
My comp suddenly would not load up all dlls and other os programs, now i cant operate any plug and play items and it wont access internet with wireless usb. it also wont operate many programs, i have run a...
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
Run reginout cleaner after this to solve th problem
3answers
Bootmgr missing
Hi
Thank you for your query
If bootmgr is missing then im afraid you will have to reformat the PC,
To reformat please do the following
1) Put your recovery CD into your drive and then restart PC
2) Follow the onscreen instructions to recover your PC
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Toshiba NB205-N330WH Web camera application missing DLLs after upgrading from Win 7 Starter to Win 7 Pro
serach, found, and copied missing DLLs from another computer (DELL) which has a Web camera to the Toshiba
Iertutil.dll
It might have been caused due to some problem in internet explorer 7(IE7)
Try to uninstall IE7. You can use the following method if it does not show up in add/remove programs.
Reference: http://support.microsoft.com/kb/927177
NOTE:
IF SP3 was installed AFTER IE7, you MUST uninstall SP3 first, uninnstall IE7, then re-install SP3. If SP3 is NOT installed, simply follow the procedure as shown.
Step 1:
Make hidden files and hidden folders visible
Click Start, and then click My Documents.
On the Tools menu, click Folder Options.
Click the View tab.
In the Advanced settings list, under Hidden files and folders, click Show hidden files and folders, and then click OK.
Step 2:
Uninstall Internet Explorer 7
To uninstall Internet Explorer 7, follow these steps:
Click Start, and then click Run.
In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
Follow the wizard instructions to uninstall Internet Explorer 7.
I have down loaded ie7 but cannot load it.
Your Windows installation is most likely corrupt, meaning you have bad files for Windows. Most likely caused by a virus that is still preventing you from installing an antivirus program. If you have a recovery cd, now is a good time to boot from it, just copy your important files to a thumb drive or other media before doing so in case it wipes them out. Another options is running the System File Checker utility to replace/repair Windows System Files. To do so (you will need a Windows CD), Click Start button -> Run -> type "cmd" and click OK button. In the black window, type "sfc /scannow". It may prompt you for the Windows CD. This will check all of your core Windows files and replace any missing or bad ones.
5helpful
2answers
IE7 flashes briefly when I click on it and then goes away
This usually happens after installation. 1. Click START–>RUN and type cmd
2. At the prompt, type cd and press ENTER
3. Type cd Program Files and press ENTER
4. Type cd Internet Explorer and press ENTER
5. Type regsvr32 IEPROXY.DLL
6. You should get a confirmation that the IEPROXY.DLL has been registered. You can then close all windows and try Internet Explorer again.
If these steps don’t solve the problem, try
Launching IE with add-ons disabled:
1. Click START–>RUN
2. Type iexplore -extoff
You can also create a shortcut so that you can always run Internet Explorer this way.
1. Right-click on the Desktop
2. New–>Shortcut
3. Enter in iexplore -extoff
Hope this helps
Chris (ziraffa)
Errormessage keeps coming up Application has failed to start because msjter35.dll was not found reinstalling the application may fix this problem
After you download "*.Dll"(file extension dll) on your machine, copy it to
windows/system32/
Go to "start" ==> "run" and type "regsvr32 *.dll" to register the file to the system. For windows 95/98/xp/2000/vista,and win vista,no dlls is corrup!
where should this file go?
Please copy it to windows/system32/
We offer Free System Scan for Dll errors, ocx errors,and thousands of other frustrating Windows errors.Speed up your computer.
http://www.dll-download-system.com/dlls-download-m-/msjter35.dll.html
you will find the link and you can download this file
1helpful
3answers
Dlls for kernel
Error Message:
Load needed DLLs for Kernel Translation:
Important Windows XP program files are missing or damaged.
Solution:
This error is confusing for several reasons. First, many users may not understand that the kernel is the main program file in WinXP, the heart of the operating system. Second, the term “load needed DLLs” is just ambiguous enough that you might not know how serious the error really is. Unfortunately, this problem cannot be corrected by just rebuilding the system Registry or restoring files from the WinXP installation CD. You’ll need to perform an “in-place install” of the operating system, which will destroy most of your settings such as Internet Favorites and all of your applications. The good news: An in-place install will usually not overwrite files in your My Documents folder and will keep other files located in other directories (as long as they are not operating-system-related). To perform an in-place upgrade, you’ll need to boot from the WinXP CD, which might require that you enter the BIOS (Basic Input/Output System) of your computer and enable the Boot From CD option. Then, when the install starts up, select the Install WinXP option and follow the remaining instructions.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
