Question about Ricoh Aficio 2020D Copier
Right door off hinge, cannot get back on
Was recieving a fax when the error came up to check right door and follow directions. When I went to open the door, it came off alltogether and is hanging on by a spring. I cannot get the door to go back on. Do you have any tricks to get it?
  • Ricoh Master
  • 2,794 Answers
Its probably missing the pin to hold the door in. It should be serviced by a technician to get it fixed.
Posted on Jun 26, 2008
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
I always get confused as to the door swing direction and I need to replace one of the handle sets. Before I order I need know if it is a right or left hand door. Can you help?
Yes, Here's how. It's all about the hinges. Facing the door from the outside, if the hinges are on the left, and the door swings to the inside, it is a left hand opening door. If it swings in with the hinges on the right, it would be a right hand opening door.
Best regards, --W/D--
Jan 28, 2011 | Garden
I have brother mfc 8440 left hinge was broke. i replaced it . noe error message . check oringal message is comming
Most of the time a door has a sensor on it or on the hinge that senses when the door is opened and closed. It looks like a little flag that passed between two sensors. Some times that flag is broken off or not passing directly between those two senors. Check around the hinge that you replaced for one of these.
Apr 26, 2010 | Office Equipment & Supplies
I am receiving coof0401 error code when powering on.
  • In order to resolve this error, follow the steps below:
  • Check the paper feed rollers:
  • Remove the power cable from the rear of the unit.
  • Open the rear access door.
  • Rotate the paper feed rollers in an upward direction.
  • Reinstall the rear access door.
  • If the error persists, go on with Step 2.
  • Perform a power cycle:
  • Verify that the unit is powered on.
  • Remove the power cable from the rear of the unit and wait 20 seconds.
  • Press and hold the POWER button and insert the power cable.
  • If the error persists, go on with Step 3.
  • Perform a semi-full reset:
  • Unplug the power cord.
  • Press and hold # and 6 simultaneously while plugging in the power cord.
  • Turn on the unit.
  • Semi-full reset will do the following:
  • Change the user settings to the factory defaults.
  • Fax logs.
  • Fax headers.
  • Fax speed dial information.
Please rate my response!!!
Jan 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
I am a quailified Gas Safe regirtered engineer who has a problem with a Smeg Range A1.1 oven door hinge reciever. We have been in touch with Smeg direct and asked for the required information as to the...
HI ,I have just managed to remove hinges from a smeg a1.1 range. to get hinge out you have tohook up a small holding catch on the bottom bar and thenforce open the hinge, the topbar thencatches on the small catch which then holds the complete hinge open .The whole assembly can then be pulled out. The holding catch is only about 1" long but is easily flicked up with a screw driver Paul 07776 438 408
Oct 26, 2009 | Smeg A1A.1 Gas Kitchen Range
52 saccaner error
52 Scanner Error Perform the following to troubleshoot a 52 scanner error:
  1. Verify that the toner door is completely closed. If the door is not closed, the printer will not allow the laser shutter to operate and will present the error “52 Scanner Error” or “Door open or no print cartridge”.
  2. Verify that the black connecting link to the toner door hinge is properly attached. If the latch is not properly attached (Figure 1), snap the hinge in place, close the toner door, and power-cycle the unit. Figure 5: Black toner door latch c00162195.jpg
  3. Verify that the inner toner door is properly positioned. Snap the door back into place at the two inner door-locking mechanisms (Figure 2). Figure 6: Inner door locking mechanisms c00162197.jpg
  4. Verify that the door hinge and upper ring are not broken. If either are broken, the unit will need to be returned to HP or a local service provider for service using the applicable warranty, support pack, or contract option. Figure 7: Door hinge and upper ring c00162200.jpg
May 28, 2009 | HP LaserJet 3055 All-In-One Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Replace drum error
Hit the clear button with the front door open. this i believe is to clear drum counter. just follow the directions that came on a piece of paper with the drum.
Nov 26, 2007 | Brother IntelliFAX 3800 Plain Paper Laser...
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
