Question about Nintendo DS Console
Lines on ds screen
Ok,my ds touch screen is normal,but the top screen gets lines when im playing ,and then the top screen gets frozen,but the touch screen is normal,i hope you get what i say help me!!!!!!!!!!
  • 20 Answers
This is a normal problem dont worry, have u spilled water on it or has it fallen a few times? that might be why its doing that, if u havent done any of those things then maybe the screen is disconnected to some thing in the ds try and get it fixed
Posted on Oct 26, 2008
Why does dslite have no power?
Make sure the ribbon cables or the screens are plugged in. one for each screen and one for the touch screen (i think the touch screen is the one thats causing your problem) its small and comes out easily. please wright back if it works
Sep 05, 2014 | Nintendo DS Lite
The top screen on my ds lite keeps flickering lines. this gets worse the longer it's on for but it does seem to help if i play while on charge or close and re-open the ds. I'm not sure what needs replacing...
It might be worth checking the ribbon cable for the top screen is tight in the socket on the main board, this could explain why the screen gets back to normal when you close the ds then reopen. The ribbon cable for the top screen is in the hinge on the left side of the ds when open, the only way to check this is to take the back of the ds, to do this you will need a small philips screw driver and a tri-wing screw driver which you can get of ebay quite cheap. The worst possible fault is the top screen is faulty and needs to be changed, if you do a search in youtube you will find videos on how to do this, they are good and quite detailed. hope this helps.
Feb 17, 2010 | Nintendo DS Lite Pink Console
Hinge and Top screen of my Ds lite is broken.... T-T
you would need to replace the top screen ebay has them cheap
top lcd item no. 380136107562
a replacement shell can be bought for around £10 +
depending on what design you would like
Aug 27, 2009 | Nintendo DS Lite Console
Top half dont work
Solution:
1. IF you have R4 card in your DS, take it out.
2. Go to Settings (Little icon on the bottom of the touch screen)
3. Select Pink button
4. Select "GBA Mode" (pink button on the right)
5. Select "Touch screen"
NOTE:
This is mainly affective for GBA games, not DS games unfortunately.
If you are really that desperate to play DS games properly, then either hope you can still claim it on warranty and/or buy a brand new DS (maybe even the new DSi).
Hope I helped
- donman92
Jun 01, 2009 | Nintendogs: Dalmatian & Friends for DS
There is a line on my DS
The pixels on the screen are starting to go bad which is why you are having lines starting to show up, the screen needs to be replaced to fix the problem.
May 03, 2009 | Nintendo DS Console
Lines on Touch screen
I know if you use a DS stylus on a DS lite it will mess up the touch screan i dont know what DS you have though and your not suppose to touch the top screan with the stylus. Try reading the DS manual I don't know what to do...
Nov 16, 2008 | Nintendo DS Console
Blank screen
im sorry your ds has a big problem you will have to get it sent off for repairs, either game repair shop/busyness or the place you bought your system from
Apr 06, 2008 | Nintendo DS Lite Console
Nintendo DS behaving erratically-Screen malfunction????
Normally replacing the touch screen will fix these types of problems. Please note that there are two screens on the bottom and not just one. You have the touch screen and under that you have an LCD screen just like the LCD on the top. You will have to remove the touch screen from the LCD as it has double sided foam tape holding them together. Also, the small clip that holds the ribbon cable to the board is easily broken, so be careful with it. If you break it you will not be able to get the ribbon cable to stay in and the touch screen will no longer work and your DS will likely not stay on.
Mar 29, 2008 | Nintendo DS Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
600 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
