HD 1080p TV
I recently bought a 1080p HD tv and while i do not have a hd reciever and blue ray player yet I intend on getting one I am looking for info on what cables I should use and the pros and cons for regular RCA cables(red,yellow,white) and componet cables. How are they different and why I should use what to get the best picture. Also componet cables carry only video so does that mean I also need audio cables (red and white) to carry noise? I want the best picture seeing as how I spent all this money on a HD TV. Reall quite confused about it all.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey peterman,
Depending on the TV model that you purchased, you may have four to five different options that you can use to make the necessary connections for your home theater: composite, component, S-video, DVI and HDMI cabling.
Composite cabling may often be considered to be the "lowest quality" type of cable that you can use to connect two devices in your home theater, and generally consists of three color-coded cables: one yellow, one red and one white. While the yellow cable is typically used to transmit the video signal to your TV, the red and white cables transmit the right and left audio channels respectively. Composite video is somewhat limited in the fact that it is primarily intended for use with analog TV sets - by using composite cabling you may limit the quality of picture your HDTV is able to display.
Analog component cabling then can be viewed as a “step up” from composite cabling. Rather than transmitting video information over a single cable, component cabling instead uses three. Each of these cables transmits a different portion of a video image, and can often be found in bundles with one red, one green and one blue cable. Please keep in mind that component cabling still requires the use of a secondary cable to carry an audio signal, which may need to be purchased separately.
The primary benefit of using component over composite cabling is that many users may report a cleaner, more brilliant image on their TV as a result. This is not a guarantee however, as picture quality is often based as much on personal preference as it is the actual configuration and settings of the equipment used.
Often considered “in-between” composite and component cabling is S-video. Like component video, S-video cables split the information sent to your TV into multiple analog signals…two signals, to be precise. Unlike component video however, these two separate signals are sent using the same cable. Again, when using this type of connection a separate cable for audio signals is necessary.
DVI cabling is the first truly digital option available to most consumers. While it only carries a video signal (like its analog counterparts), DVI cabling can frequently be found connecting computers to monitors or digital projectors. These types of cables will have a unique shape that prevents them from being used as anything other than a video connection, and were designed to optimize signals transmitted from external devices to a visual display.
HDMI on the other hand, is another widely available digital alternative. Unlike DVI, HDMI cables support both video and audio signals, allowing consumers to avoid the proverbial “rat’s nest” behind a home theater system that one might encounter when using multiple cables.
Because HDMI cabling was developed to be backwards compatible with DVI, HDMI and DVI connections may often be able to be used interchangeably using special adaptors. Essentially, if your HD receiver/Blu-ray player only has DVI outputs and your HDTV only has HDMI inputs, you may still be able to connect those devices to your HDTV using the proper accessories.
While some major retailers may recommend using HDMI cables first and foremost over the other alternatives, this does not necessarily always make them the best choice to use. The quality of an image displayed on an HDTV will always be dependent as much on the TV itself, as it is on personal preference and other external devices. Yes, the type of cables used does play a part, but they should never be treated as the only factor to consider when setting up your home theater.
Should you have any questions or lingering doubts, I would strongly suggest speaking with a Magnolia Home Theater agent at your local Best Buy™ store for more information. Most stores will have similar TV's on display using more than one type of connection, and sales associates are always able to provide additional suggestions if desired.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 24, 2008
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Tv comes on but on picture1080p
If you have sat or cable box be sure they are HD capable and are connected to the HDMI or Component input on the TV . Only HD channels will be in 1080i. No one broadcasts in 1080p. Only Blue Ray DVD players of Game machines are 1080p.
Dec 26, 2010 | Televison & Video
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
How do i get my tv to run 1080p
A 1080p set will only show 1080p if the broadcast or satellite co sends it. I don't know of any cable co's doing that as yet. True HD isn't in full motion as yet. 720p is your best right now unless you have a Blue Ray DVD Player along with a 1080p full hd movie then you can watch full HD.
A lot of stations are running 1080i which is good for slow motion movies. 720p is best for fast action movies.
Nov 27, 2010 | Mitsubishi Televison & Video
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
Want to add all of my video components to my rxv 663 reciever
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Feb 01, 2009 | Yamaha RX-V663 Receiver
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
