Question about Vector Black And Decker High Frequency Automatic Battery Charger
How long to run battery on "recondition" selection on Smart Charger
How would I go about getting a charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
May 20, 2015 | Vehicle Parts & Accessories
Tip
WORX battery chargers
I'm going thru same prob. with 24V battery for WG167. Had same thing with older 18V that came precharged & then wouldn't recharge. 3 batteries later, they sent me to a "technical" rep who said "NO NO, it's not the batteries, it's the charger" He sent me a reconditioned charger & it worked fine. I'm not having any luck so far with the "MAX 24V". On my 2nd battery. It didn't come precharged & will only charge to 18V which is what the charger is outputting! Trying to get a "tech rep" to diagnose but no luck so far. Their tools are handy & work well if you can just get the battery/charger resolved!!!
on Sep 20, 2013 | Worx 10" 24v Cordless Li-ion Trimmer/edger...
Tip
HOW TO FREE MORE RAM ON YOUR S60 MOBILE
<p><b><span style="font-weight: bold;">How to free more RAM on your phone&gt;</span><br /></b><br /> <p><b>Method 1: Flight mode:</b><br /> <p>Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM!<br /> <p>Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case.<br /> But i've also heard several reports of people who have both apps running without any problems.<br /> <br /> <p><b>Method 2: Smart Launcher trick:</b><br /> <p>Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON.<br />Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold).<br /> The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM).<br /> <p>The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when<br />the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when<br />you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so<br /> you trick the phone and you have more free RAM!<br /> Note: when you unplug the charger, the phone will switch off.<br /> <p><b>Method 3:<br /></b><br /> <p>It frees a little about 100~200 KB but I guess it's useful sometime. Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit"<br /> <p>So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradis.<br /> <br /><br />
on Mar 04, 2011 | Cell Phones
I have a Vector Smart Battery Charger 2/6/12 model VEC1088A-M. I am trying to charge a trolling motor battery but I get an error messager "F03." What does this mean?
F03 means 1 of 2 things:
INTERNAL OPEN CELL - Bad battery. Battery needs to be replaced or
SULFATED CONDITION - Battery needs to be reconditioned for 24 to 48 hours. See owner's manual.
May 27, 2011 | Computers & Internet
I've tried this charger on 3 batteries and always get "check connection" light, and flickering "battery charged" light. I've pinched clamps and connections are very good...I've left...
Smart chargers will fail to charge completely discharged battery. Simple charger w/o electronics will. Try connecting two batteries together with charger. ALL in parallel. + to +, and - to -.
Mar 03, 2018 | Minn Kota MinnKota MK110P Marine Portable...
How long and how to reconditioning the battery
the battery can only be reconditioned if it is not working properly due to a scale build up on the plates of the battery, if a cell is shorted out ,it will have no effect to "recondition it" . if a battery needs to be reconditioned to work properly it is probably close to the end of its life cycle and it will be a temperary fix
Feb 22, 2011 | Vector Black And Decker High Frequency...
I have a HP 6735s Laptop. I have been getting a few of the "Smart AC Power Output" messages, however yesterday after I turned my laptop off and then on again, the laptop wouldn't detect the AC...
bad battery,
you do know that the main batteries are "love to fail"
right,
just about all batteries do that in everything,
even the coin cell,inside can fail in 5years flat.
if power pack is 19vdc with volt meter, good !
the battery is next, yes it runs pc but can be bad.
a bad battery can still have power but overloads the charger chip
it really is an analog world. (reality)
if savvy , always keep a spare battery for moments like this.
Apr 07, 2017 | HP Compaq 6735s Notebook
Vector Black And Decker High Frequency Automatic Battery Charger Logo
288 people viewed this question
Top Vector Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Vector Tool and Hardware - Other Expert? Answer questions, earn points and help others
