Question about Lands Phones
How do you get the music thing to work with my new wireless headset. It is compatible but I don't know what to do and the manual does not specify anything.
  • john yray
    john yray May 11, 2010
    What music thing bestmomever? What's the model of your phone?
  • 161 Answers
Are you sure it really is compatible? If it was all you need to do is plug it in your phone, that would make the sound go out the earphones.
Posted on Jun 28, 2008
Why i cant stream music from my iphone 4s to play in my nissan 370z via bluetooth
Not sure, If the manual, from the car radio says it should pair with Apple bluetooth devices, it must be a setup problem. If your radio is not (yet) compatible with MP3 over bluetooth from Apple devices, you should ask nissan if they have intentions to upgrade the software in the radio. I think you spent enough on your car, to get this kid of service.
I'm sure most modern car radio's are compatible, because my 2 year old Toyota Yaris can play my music and take my calls from my iPhone 4 without problems.
Jul 22, 2014 | Plantronics Explorer 220 Bluetooth Headset...
Cant listen to music on my Blackberry Pearl using HT820
I'm not familiar with Bluetooth and Blackberry's but I think you need a driver or you need to "sync" your media player on your Blackberry with your headphones.
I'll do some research and get back to you.
Feb 20, 2008 | Motorola Mobility HT820 Wireless / Cable...
There's a distinct crackling sound on my Headset. What can I do?
I have the same problem, but only in Windows, and only on my laptop (It's a Compaq 515). I do not get the problem if I pair it with my phone, or if I plug the receiver into any of my other computers. The big thing is: If I reboot into Linux, the noise stops.
Feb 08, 2013 | Logitech Wireless Headset H600 Overthehead...
You don't specify which headset that you have. I would need to know which one and check all the connections to know why you aren't hearing a dial tone.
Here are a few things you can try -- try checking all the connections, unplug and replug back in, make sure that they are in the correct slot.
If it is a wireless headset say like a CS50-CS55 there is a 1-4 on the side, check to see if the #1 is in a 3 O'Clock position.
Is this a computer headset, wireless, corded, bluetooth, MP3?? Can only give recommendations of things to try.
Good luck from Headsets Direct!
Aug 24, 2011 | Plantronics Radio Communications
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
When I use my wireless headset the speaker makes a rapid clicking noise. When the amp is on by itself, there is no clicking coming from the speaker. The box that plugs into the wall for the micro. does...
This is related to the connection of the two devices together. They operate fine when used separately.
Take your wireless system and amp to a knowledgeable local music dealer so they can see the entire thing and help you troubleshoot.
Dec 01, 2010 | Shure PGX14PG30 Wireless Headset
I have a bt-10 i have let it charge for about 4hrs an it want come on after I unplug the power source
Check the manual that came with it. (You DID save the manual, right?) It should tell you just how long your supposed to charge your headset, as well as how to turn it on properly. I have a Plantronics Bluetooth that seems to take forever for the On button to work, but it works just as specified when I time it.
Oct 04, 2010 | Just Wireless Bluetooth Headset Wireless...
Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
May 23, 2010 | Motorola Mobility H500 Wireless Headset
Motorokr S9-HD headphones does not pplay music with Fusic phone
On your smartphone, you need to enable the bluetooth wireless headset settings. There may be a seperate setting on your bluetooth options for enable wireless headset and enable wireless handsfree.
You may also want to check and make sure the volume is turned up all the way on the smartphone media player and on the headset.
Jan 12, 2009 | Cell Phones
Will the BT8010 work with the iphone?
NO. It's not compatible. I just bought one today.
Jan 06, 2008 | Jabra BT8010 Wireless Headset
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
