Wht wire gauge 2 choose?
Bought a new receiver,a sony str-da4300es what speaker wire gauge number should get and wht the number means? thanks 4 ur time
  • 121 Answers
You can run anywhere from 12 to 16 guage speaker wire. The higher the number the thinner the wire. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
Hi I purchased a sony av amplifier model STR-DB930 on e-bay a few months ago and I am using 3 ohm speakers from my old surround sound system. The output selector on the back of the unit is set to 4 ohms....
The lower number in Impedance specs is not a suggestion. It's a limit. 3 is not between 4 and 8.
Register and download the manual for free at
If you don't want to buy new speakers, settle for safer low volume levels.
You're going to kill that receiver driving a 3-ohm load. HTS-style speakers aren't reliably re-deployable to other electronics. Perhaps, if you have 4 speakers and they're similar you could wire them in SERIES and present a 6-ohm load to each channel.
Re-engineering the speakers themselves is, well, don't do it. It isn't rocket science but it also isn
Feb 28, 2011 | Sony STR-DB930 Receiver
I just bought a new Sony STR-DH510 reciever, I connected a sub woofer and 2 surround sound speakers to it and it worked perfectly. The next day I go to turn it on and it will turn on for about 30 seconds...
Problem is in the amplifier output stage...there is probably a shorted component...the short could have come from a bad speaker..or the speaker wires getting touched together while it was could return to store if it is new and get a new one...maybe it was a return and accidentally got put back into stock
Jan 20, 2011 | Sony STR-DG510 Receiver
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
Jan 08, 2011 | Sony STR-DE335 Receiver
Sony str d-1015 stereo receiver stopped working
if you have been blasting it, that could be why, recievers of this era are made with cheaper parts that cant handle what theyre supposed too,
i dont know specifically, but things like that have some sort of auto fuse...
i would assume, you are using it with wrong ohmage speakers, are you using car speakers? car subs? older speakers?
most home stereo equipment is 8 ohms, i have a set of 140 watt 3 way (10"[vented]/4"/2") as fronts and a set of 80 watt rears (6"[vented]/1.5"/24mm) the fronts are induviduals, meaning they have to be bought individually, and are not sold as a set, or part of anything, the rears were part of a bookshelf system, i got the set secondhand... but i always checked the ohmage...
Jan 08, 2010 | Sony STR-D1015
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
May 19, 2009 | Sony STR-DE685 Receiver
I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Apr 04, 2009 | Sony STR-D565 Receiver
Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
May 27, 2008 | Sony STR-DB940 Receiver
Sony STR-V333ES repeatedly clicks when i try to power it up. is there an internal fuse???
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Feb 19, 2008 | Sony STR-V333ES 5.1 Channels Receiver
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
77 people viewed this question
