Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
No Power I couldn't turn my tv off this morning before work with the remote or trying the television directly, so I unplugged it. I came home, changed the batteries in the remote, plugged the tv back on and still nothing. The remote won't work and I can't turn it on manually. Unlike other users, I didn't hear a pop or anything. thoughts?
  • kguedez Jun 24, 2008
    I have a similar problem. What is the solution? I have already umplugged it and no changes.
  • Jcooper421 Jun 29, 2008
    I have the same problem and the tv is just at 6 months old. Has anyone been able to fix this issue? We have unplugged the tv and it worked 20 minutes then the same thing keeps happening. I am starting to get very fustrated with this tv. I do not expect this from a almost $500 tv.
  • 426 Answers
If you need any other help please feel free to e-mail me at
Posted on Jun 24, 2008
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
I have a Vizio SV48OM. It is hooked up to Dish. this morning I couldn't change channels or anything with my dish remote but could turn the tv on and off. Called dish and was trying to see what the...
About the only thing you could try would be to reset both the dish receiver and the tv. Disconnect both from electrical power source, (unplug) after a minute or so, plug them back in and try again. if neither works then you may have had some type of power surge.
Be certain your tv is in the right source, however the tv has been connected to your receiver.
Oct 29, 2013 | Vizio SV470M LCD TV
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
We have a 42 inch flat screen that was working fine this morning before I left for husband turned it off from the tv instead of the remote as I always do - we have Direct TV - when I came home I...
Does it work when you use the DVD player? Or just the problem when you are trying to use Direct TV?
Dec 10, 2010 | Digital Lifestyle Televison & Video
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Lg lcd tv remote code
Lg lcd tv remote codeTRY ANY OF THESE: 140, 024, 040, 098,043, 259,260, 261
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Big Screen TV won't turn off
Check the voltage to the relay, usually 12v dc. Also check the relay or replace as it may be stuck after the tv warms up. The micro chip for functions could be locking up. Try spraying a little freeze spray directly on chip after tv is locked up see if this unlocks, if it does you have a bad micro chip.
Jul 20, 2007 | Philips 55P8241 55" Rear Projection...
Remote control not working
if you still have a problem (and the tv!) email me at
May 01, 2007 | Protron PLTV-32 Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
