Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Motorcycle Starter repair for 1994 hd 88 cubic inch evo motor
My starter is not engaging the motor. It spins but wont turn over the motor. I have taken the first one out and replaced it with a loaner from a buddy. It worked about 15 times and started doing the same thing just spinning and clicking but not engaging the motor. So I had the original bench tested its fine so I put it back in and it work about 12 times. Same thing all over again. What do I do it has me a a bunch of my buddies lost.
  • loudashell Jan 16, 2009
    1998 Softail Custom:
    starter spins but will not engage motor this has happened only a few times before but always reengaged and started the bike tonight I tried to get out for a ride and it would not engage at all only spining and the battery is new
    more than enouph juice is getting to the starter.
  • DynaKing Feb 24, 2009
    Harley FXDS Conv. 1340cc. starter spins but takes its time engaging. It always starts though. Sometimes it will engage immediately, but only after a short stop on a long ride. It is getting worse as time goes by.
  • 91 Answers
Check the battery if the starter tested good the starter spining and clicking and not engaging the starter suggest the solonoid is suspect it kicks the starter out might be going bad. BATTERY is the common factor with the three starters working about the same lenght of time
Posted on Jan 15, 2009
Starter spinning wrong way
Wow. Probably the positive and negative connections have gotten reversed in the solinoid and starter motor. Still stuck? I recommend a DIYer's repair manual that shows electrical connections for the starting system.
May 07, 2015 | 2003 Yamaha FJR 1300 A
KTM 530 2009 starter spins but motor will not turn over
Hi, Anonymous the starter clutch is a separate mechanical gear driven component that is activated by the starter motor, it engages the clutch pack gear or the flywheel gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one "ONE DIRECTION" only and once the engine starts allows the gear to free spin with engine rotation. If the starter gear free spins in "BOTH DIRECTIONS" then the drive gear has failed, it might be serviceable on some models but usually needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Need Help Electric Start wont start but kickstart does
KTM starter problem slow crank solution and bendix fix
KTM 450 EXC EU Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 450 EXC EU Owner Manual
Oct 12, 2017 | 2009 KTM 530 EXC
1994 virago 1100. Starter spins but wont turnover motor.
Hi, Manuelverdin the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.viragohelp.com/virago-owners-clubvoc-archives/virago-starter-repair
Yamaha Virago Motorcycle Starter Bendix Explanation Fix Pt 1
Yamaha Virago XV1100L Owner Manual
OEM parts for Yamaha
Yamaha Virago XV535 1100 1981 1994 Service Manual
Apr 25, 2012 | Yamaha Motorcycles
Battery is good but when I turn it on it just clicks won't start,maybe after 20 times it starts
Without hearing the sound it makes - it's kind of hard to diagnose.
The engine starting process consists of turning the key to start, the starter motor's rotor moving forward to engage the engine's flywheel, and then the starter motor 's "rotor" spinning until you move the key from "start" to "run". You can hear the starter motor spinning - but one usually can't hear the rotor moving forward to engage the flywheel. As a result, you hear the odd spinning sound - which is the starter rotor spinning. The engine never actually turns over because the rotor never engages the fly wheel. If this is the case, then it is very likely that your starter needs to be checked and / or replaced.
Nov 09, 2011 | 1994 Buick LeSabre
I have a Hartford Legion 125 W reg 2000 model which looks like a Honda 125 cg. The problem i have is the electric starter turns over the engine quickly but wont fire up the engine. It has a kick start and...
Hi, Taffyrhys the starter clutch is a separate mechanical gear driven component that is activated by the starter motor, it engages the clutch pack gear or the flywheel gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one "ONE DIRECTION" only and once the engine starts allows the gear to free spin with engine rotation. If the starter gear free spins in "BOTH DIRECTIONS" then the drive gear has failed, it might be serviceable on some models but usually needs to be replaced.
2001 Hartford Legion HD 125L replace starter clutch Google Search
cg125 how to fix starter motor part 1
Search
12results for hartford hd 125l
Hartford HD 125 Legion 2003
Sep 04, 2017 | 2001 Hartford Legion HD-125L
Harley davidson evo motor wont turn over...just clicks
Pull the spark plugs out and hit the starter. This will make sure that the engine is not locked up. If the starter does not turn the engine, put the bike in first gear and have someone push you, making sure the engine is free. If the engine is OK, your starter is probably jammed and needs replaced. That wire getting hot is a dead giveaway something is locked up tight...starter or engine. If ya have a large hi-performance engine in the bike, chances are your stock starter won't do the job.
Jun 16, 2009 | Harley Davidson Harley-Davidson Motorcycle...
1999 ttr 250 starter motor is not engaging
I would guess it is the starer clutch, also called the one way clutch. I went on to www.bikebandit.com and looked up your bike and it has a nice exploded veiw of your starter clutch . I will try to put a direct link to it , hopefully it will take you to it. http://www.bikebandit.com/houseofmotorcycles/yamaha-motorcycle-tt250rl-1999/o/m7707
if not go put in your bike and look under starter clutch.
May 19, 2009 | 2002 Yamaha TT-R 250
1998 Harley Davison Evo starter boggs down when trying to starten
do you have commpression releases on your motor if not you may need to in stall this will ease the stress off your starter and your motor will turn over easier if you do have the releases not sure what you may need to do without hearing the drag to determine if gearing is issue
May 15, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Location starter solenoid 1994 Olds 88 Royale
The solenoid is on the starter. The starter is located on the engine between the radiator and engine next to oil pan.
Feb 15, 2009 | 1994 Oldsmobile 88
What going on
Bad switch or Solenoid. depending on the bike.
Mar 17, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
1,021 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
