Question about Samsung Cameras
My samsung s85 camera indicated low battery condition. I replaced the batteries with new/fresh AA batteries. When I turn on the camera, the camera starts normally, then beeps three times and shuts itself down. That seems to be all that this camera can now do.
  • hcnylkcaj Jun 25, 2008
    analclownsarentthey!
Their ranking equals SKUNK
Posted on Jun 26, 2008
Deeees guuuys are twirps. give dem noting
f+1 u+2 c=3 k=4 e=5 r=6 s=7
add the letters seperately, forget the equal signs and numbers
then the answer will appear
DO NOT USE OR TRUST FIX YA
SCAM YA DILLLDOESS
For the small sum of only $9.98 you can purchase my experts method of fixating the problem that fix-yore-**** wouldn't do. What a scam.
The fix is simple and effective and you can get it quickly for 10.99 in addition to the base price of only 9.98 and have yore dream fix right before yore very ****..
email me personally at : jack@oath.com
if you are for real, I'll tell you the simple fix. If you are fixya, eat me
Posted on Jun 25, 2008
It will say low battery or will not turn on
If your camera uses AA batteries, you should note the battery type your camera support, and many cameras only support Lithium AA batteries or Alkaline AA batteries, else there maybe note enough voltage, so the camera will note low power. If your camera uses special camera batteries, and maybe you should replace it for a new one.
Sep 05, 2011 | General Electric A950 Digital Camera
I have loaded 4 new AA batteries and try to take a pic and "battery empty' appears in scrren and will not take a picture.
Be sure to have real fresh alkaline AA of fresh recharged NiMh batteries.
Good rechargeable batteries are Sanyo ENELOOP NiMh batteries, which have a very, very low own discharge. Some other brands have them too.
May 05, 2011 | Olympus SP600UZ Digital Camera
I have a samsung 860 digital camera ang my problem is the lens... the lens is still retracted even its turned off... before it happened the camera have a low battery.. and when i charged the battery for...
This may be similar to another solution posted. Try heavy duty batteries - I used ACDelco Super Alkaline, but any brand of "heavy duty" AA should work. Make sure battereis are not cold; low temp causes any battery to lose power. If fresh heavy duty batteries do not help, it may need professional service. (DO NOT try to force the lens back to retracted position - something WILL break.)
Dec 18, 2009 | Samsung S860 Digital Camera
I put in fresh batteries and camera still wont turn on.
wen i turn it on it makes a beepn noise then cuts off with no picture
Aug 18, 2009 | Samsung S85 Digital Camera
Samsung S85 problem
I have had similar symptoms that seem to be due to battery power.
Using and OHM meter I find that the Samsung S85 eats batteries. If the charge drops to 1.4 something volts from a 1.5+ volt battery, the camera does not function properly.
The camera is nice an compact ... but I need to carry the same volume in batteries to make sure I can use it.
Jun 17, 2009 | Samsung S850 Digital Camera
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Battery/power-up problem
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Oct 27, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
POWER GOES OFF , AFTER PRESSING POWER ON
Make sure the batteries are of good quality and very new. If the probelm persists then it will have to go to the repair shop
Jun 07, 2007 | Samsung Digimax 360 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Cameras Logo
128 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
