My cable went out during a storm. When the cable came back on, I was unable to get clear reception on my HD tv. The signal is intermittent and never clear. I am able to use the other connections(DVD, PC, etc.), and the screen is fine. I just can't get a tv signal. The other tv works fine with the cable also. The tv is an Olevia LT26HVX.
  • averyharvey Jun 25, 2008
    This does not help. My problem is not due to interference or a faulty cable connection.
  • 3,037 Answers
Do you have separate cable boxes for each tv? Have you tried the other tv on the exact same cable as the tv that is having problems? Please answer the above questions and try connecting the second tv to the same cable if not done already and let me know your findings. Your cable box may have gone bad
Posted on Jun 24, 2008
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    If you are satisfied with your experience here, then feel
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 6,487 Answers
Check this link this will help you http://www.kyes.com/antenna/interference/tvibook.html
Just inform me if it work.
Hope that helps..........
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I do not get complete picture ie picture continually breaks up (pixilates) as does sound, even sometimes no signal but only for a short time.
If it only happens while watching an incoming signal from the cable company and not a DVD playing,
I went through this too on a rear projection HD TV.
If you have any splitters on the line to the TV eliminate as many branches to other devices as possible. They cause a drop in signal strength which is the problem. Make sure the cable is RG6 others are too weak to carry a good signal.
After going through many splitters and taking other things off I got a better signal. But it came down to the cable companys box out by the street had corroded metal components and when they changed that, the problem cleared and was even able to add all devises back to my signal splitter.
If is happening on a satellite dish then check and clean or replace cable connectors.
Aug 02, 2009 | Televison & Video
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Is it the TV or Comcast?
I'VE SEEN QUIT A FEW SAMSUNGS DO THIS AND THE DIGITAL BOARD IS THE PROBLEM YOUR MODEL NUMBER DOES NOT HAVE A DASH HLR4667W AND YOU NEED YOUR VERSION NUMBER AND MAYBE THE BEST THING IS GET THE PART NUMBER OFF THE BOARD.
Apr 17, 2009 | Samsung HL-R4667W Rear Projection...
After an electrical storm last night we have lost ITV, Ch 4 etc on Digital, BBC and Sky on freeview are fine. All analogus signals are of very poor quality. Any ideas please?
Electrical Storm normally damage Tuner in TV.
Symptoms in tv like poor analog tv signal reception shows replace TV Tuner.
Regards,
Sep 03, 2008 | Televison & Video
RCA D56W20 picture problems
More information is required to properly troubleshoot this problem. How is your television connected when you are watching HD? Do you have HDMI for this, do you have a satellite or digital cable box? For analogue are you using regular coax antenna (cable TV), or are you going through a cable or satellite box?
This could be related to the aspect ration setting. perhaps you ahve changed your aspect ratio from 16:9 to 4:3 or some other setting. If you are connected via HDMI, then the digital signal may be "normalizing" your picture during HD, but reverting back to the other setting.
Check you video settings very carefully. HD televisions are very difficult to tweak properly.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HL-R6167W tv reception problems
Are you using a Hd cable box/directv or dishnetwork box?Or you are using your coaxial cable straight into your TV coax input?
Solutiondoct
Aug 30, 2008 | Samsung HL-R6167W 61" HDTV
Tv-- signal strength normal but signal on all channels "blipping" down intermittently causing freezing of picture. Have replaced aerial with high gain antennae together with aerial cable and...
When ever the picture freezes intermittendly the problem is usually poor connection on the signal line (antenna or connection on tv) or poor reception. Could be the tuner if the tv has one.To eliminate the tuner possibility try anther tv set if possible.
If you still cannot figure out the problem,let me know what kind of set up you have connected to your tv set.
Do you have a satellite or cable box and if you have splitters.
Jul 11, 2008 | LG Televison & Video
Will not receive hd programming
I don't know if someone had already answered this question so I'm volunteering my own.
The HD Receiver unit is in the back by the connectors. They are likely to need service or replacement. My went the same way.
Aug 18, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
